First post, by Bladeforce
Just a quickie. Has anyone got this game running in 3dfx mode under windows 7 x64? Game just crashes as soon as launched in all compatibility modes for me 🙁
Reply 2 of 11, by Gamecollector
Well, I still don't use Vista/Win7. So - I can't say exact way...
IIRC the game is using InstallShield3 (16-bit), so you must copy the cd content to HDD, copy 32-bit IS3 setup32.exe and then install.
The game itself need EmulateSlowCPU ACT fix only, w/o any compatibility mode.
Reply 3 of 11, by Bladeforce
Before I try it, will the 32bit application fix you stated (EmulateSlowCPU) work in windows x64 ok? Also where do i get this 32-bit IS3 setup32.exe file?
Reply 5 of 11, by Bladeforce
Ok great stuff i got it installed in windows 7 x64. Made the application fix and applied it to the main exe and it still crashes upon running. I have put dgvoodoo in the installed dir too. Tried with compatibility set to 95 and 98 still no go. Also updated the game with 1.50 patch still nothing
Reply 7 of 11, by Bladeforce
Just tried with nglide wrapper after deleting dgvoodoo from installed dir, exactly the same "Ultim@te Race Pro has stopped working" Tried with/without compatibility modes set on exe
Reply 8 of 11, by vetz
Just installed it myself from my Voodoo2 bundled disc and I get the same problem as you and Zeus on Nglide:
http://www.zeus-software.com/forum/viewtopic.php?f=10&t=285
Seems the game can't be run on 64bit Windows 7 at the current moment (I am writing "current" since there may be some smart bloke in the future who creates a fanpatch)
Reply 10 of 11, by Bladeforce
Mr Zeus, you sir are a godly genius! It works beautifully for me!! Brilliant! God, god. How did you do it? 😀)
Reply 11 of 11, by VirtuaIceMan
This is all very exciting; I only got the game to work on Win7 via WinXP in VMWare Player with Direct3D enabled and nGlide... phew. I wonder if it'll work in Win8 when I get it...
My PC spec: Win10 64bit, i7-4970K (not overclocked), KFA2 GeForce RTX 2070 SUPER, Creative Soundblaster ZXr, 16GB RAM, Asus Z97-A motherboard, NZXT 410 case, ROG Swift GSYNC monitor
