Actua Tennis
First post, by Bladeforce
Hi, I am getting an error "API error" when starting Actua Tennis on Windows 7 x64. Has anyone got this running especially in 3dfx mode if possible, Thanks 😀
Reply 2 of 29, by Bladeforce
Tried with the updated patch still getting an API error when running Tennis.exe
Reply 3 of 29, by [Zeus]
Did you run PatchInstall.bat and At.reg after replacing all files?
If so, reinstall the game and then create bat file with this command:
regedit /E myreg.reg "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Actua Tennis"
Execute bat file and post myreg.reg content here.
Reply 4 of 29, by Bladeforce
I have reinstalled the game and made the batch file and run it.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Actua Tennis]
"DisplayName"="Actua Tennis"
"ModifyPath"=".\\SETUP.EXE"
"InstallLocation"=".\\"
"InstallSource"=".\\"
"DisplayVersion"="1.00"
"VersionMajor"=dword:00000001
"VersionMinor"=dword:00000000
"Publisher"="Gremlin Interactive"
"ProductId"="TennisCode"
"RegCompany"="."
"RegOwner"="."
"HelpTelephone"="(+44) (0114) 279 9020"
"HelpLink"=".\\readme.txt"
"URLUpdateInfo"="http://www.gremlin.co.uk"
"URLInfoAbout"="http://www.gremlin.co.uk"
"LanguageLetter"="E"
"Footprint"=dword:00000002
Was I correct in doing it before adding the patchinstall.bat and replacing the files?
Reply 5 of 29, by [Zeus]
Yes, don't use my patch (files, PatchInstall.bat or at.reg) before creating myreg.reg file.
Now do the same for a different reg key (if you used my patch already, reinstall the game again).
Create a bat file with this:
regedit /E myreg.reg "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Actua Tennis"
Post myreg.reg content.
Reply 6 of 29, by Bladeforce
Ok here is the result of both in one post
Using the first key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Actua Tennis]
"RegCompany"="."
"RegOwner"="."
Using the second key HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Actua Tennis
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Actua Tennis]
"UninstallString"="C:\\Windows\\iun6002.exe \"F:\\Install\\Actua Tennis\\irunin.ini\""
"InstallSource"="D:\\"
This has both been done on a clean install without any patch applied
Hope this helps! 😀
Reply 7 of 29, by [Zeus]
1) Now click at.reg and make a reg file from:
Again, post the result here.
2) Click PatchInstall.bat and open "Uninstall or change a program" dialog window. Do you see "Actua Tennis Patch" entry there?
Reply 8 of 29, by Bladeforce
Here is my contents of the registry key you want before installing the patch
Yes i see an Actua Tennis and Actua Tennis Patch in my list of programs to uninstall
Reply 9 of 29, by [Zeus]
I know. Now I'm asking you to make a reg file after clicking at.reg from my patch for
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Actua Tennis.
Reply 10 of 29, by Bladeforce
The contents after installing your patch
"RegCompany"="."
"RegOwner"="."
Reply 11 of 29, by [Zeus]
Launch this executable from a game directory and tell me what you see.
Also, post your graphics card model and driver version.
Reply 12 of 29, by Bladeforce
When running this new exe I get an error
"ExUpdatePalette: Generating Look-Up"
My card is an Nvidia 550 Ti with 306.97 driver
Reply 13 of 29, by [Zeus]
Is there any difference when you try to launch tennis.exe with Windows 95 compatibility mode?
Reply 14 of 29, by Bladeforce
Exactly the same error when running in Windows 95 compatibility mode
Reply 16 of 29, by Bladeforce
Tried Tennis2.exe same error as before
Same error when running in windows 95 compatibility mode too
Reply 17 of 29, by Bladeforce
Is this just a program that we will never get going on a 64bit platform Zeus?
Reply 19 of 29, by Bladeforce
Thanks, Davros. I have no clue about the palleted textures I am not that technically gifted 😀
Yes the game runs on a 32bit platform with nglide but not on my Windows 7 x64
My card is A Nvidia 550 ti gfxcard
