Flight Simulator 98
First post, by Zup
Recently I bought FS98, and when running didn't detect my joystick. I applied patch1, and nothing happened. Finally I found somewhere on Internet that renaming my gaming device would help (FS98 only supports 47 or less character names).
OK, so my FS98 now detect my joystick but... don't detect any axis (I have 4 axis, and can not be selected for rudder, thrust or ailerons). Anyone can help?
Reply 1 of 1, by The Avatar
Try to configure your joystick. I've got a lot of problems with the joystick, believe in me...
Try to install your FS98 AND the joystick. Be sure that it is connectec correctly, check if there's any magic powder 😀 disrupting your connection. Be sure that all the pins are straight ahead. Try to check your joystick customer support for a tutorial how to configuring your joystick...
Of your friend,
The Avatar
