Problematic Windows games list
Reply 140 of 306, by benjamin91609
Pingu: A barrel of fun works on 32-bit windows 10, but is very problemmatic. Sadly it was not patched yet and OTVDM cannot run it.
Reply 141 of 306, by LevelUpOrNot
Is there topic with Problematic with MechCommander and MechCommander 2 ?
Reply 142 of 306, by BEEN_Nath_58
LevelUpOrNot wrote on 2021-01-27, 12:21:
MechCommander works fine under my testing. MC2 has performance issues although.
Reply 143 of 306, by LevelUpOrNot
Discrete_BOB_058 wrote on 2021-01-27, 12:36:
MechCommander works fine under my testing. MC2 has performance issues although.At least employee monitoring software has no issues
In MC2 is there only "performance issues" ?
I`m trying to play and mouse do not working. Can not find any fix for it 🙁
Reply 144 of 306, by BEEN_Nath_58
LevelUpOrNot wrote on 2021-01-27, 14:56:
Try disabling Hardware Mouse Update under Graphics if its not visible. The performance issue is fixable by deleting badcard.csv and vidcard.csv
Reply 145 of 306, by Sedaris
Hey, I just logged after awhile to share all fixes for the classic Star Trek and Star Wars games. Only after seeing this thread, I wonder if I should make a new thread with a list of Star Trek/Star Wars games or should I just post everything in here as single posts?
YouTube Channel
Reply 146 of 306, by BEEN_Nath_58
Sedaris wrote on 2021-02-02, 16:13:
Hi, I have posted fixes for Star Wars on my thread. However there may be more fixes required for a wider range of hardware and software, so you could create another thread for it too.
Reply 147 of 306, by CBM
interstate 82 and
old starwars games like starwars racer and jedi knight also requires windows xp unless there are fixes for jedi knight and starwars racer in the starwars thread mentioned earlier
for modern windows openttd works just fine for that ttd fix
nfs 3 and 4 have patches for both xp and modern windows
Main PC SPECS:
CPU: AMD Ryzen 5 2600
GPU: Powercolor Red Devil Radeon RX 5700 XT
RAM: 8GB*4 Corsair Vengeance LPX DDR4 3200MHz
Motherboard: ASUS Prime B450M-A
PSU: Corsair RM850
Reply 148 of 306, by CBM
Discrete_BOB_058 wrote on 2021-02-02, 17:35:
how do I find your thread? I really want starwars racer and starwars jedi knight to work in windows 10
Main PC SPECS:
PSU: Corsair RM850
Reply 149 of 306, by BEEN_Nath_58
CBM wrote on 2021-03-12, 14:58:
Both games can be installed through OTVDM. Racer may not render graphics properly, in such case use dgVoodoo 2 or DDrawCompat.
For Jedi Knight, I don't know which game you are referring to but for DF2, it's again OTVDM to install the game.
In either of the games, use administrator privileges.
Sometimes the game may not run at all or throw a 0xc00000142 error when you open the executable, in such cases rename the executable and run it.
Reply 150 of 306, by benjamin91609
ToonTown Online (2003) will be a pain in the butt to get running if the video card you are using does not have vintage D3D support (e.g Radeon 550/570 can run modern D3D stuff like the steam version of Halflife 2, but Doom3 cannot run). If the system has a midrange IGP (such as Radeon Vega 8 ), TT will run
Reply 151 of 306, by lafoxxx
Driver (1999)
Reflections interactive
Cars have no wheels in Win10
Reply 152 of 306, by Caluser2000
lafoxxx wrote on 2021-06-12, 22:35:
Driver (1999)
It's 22 years in the future, they shouldn't need wheels. I've waiting around 50 years for my Jetson's a car to turn up.......
Reply 153 of 306, by BEEN_Nath_58
Driver (1999)
Use dgVoodoo2 or DDrawCompat.
Reply 154 of 306, by James T Quirk
umm, not sure if this has already been mentioned somewhere, but My solution for Old Games, in Win7-10 is Build a FAT16 Partition on your HDD, 500meg is enough, install & Run the game from there .. Some oldies can't handle Fat32 or NTFS, it seems..
Reply 155 of 306, by xcomcmdr
Discrete_BOB_058 wrote on 2021-01-29, 11:24:
Delete dbghelp.dll and imagehelp.dll from the game's folders. This is the real fix, as discovered by Dege on this very forum.
Reply 156 of 306, by Carrera
xcomcmdr wrote on 2021-06-16, 08:35:
Cool!
Reply 157 of 306, by BEEN_Nath_58
https://www.pcgamingwiki.com/wiki/MechCommander_2
I can't say whats posted here is not real, at least it works for me. And someone from Mc forums must have discovered it. I will check out Dege's fix when possible.
Reply 158 of 306, by filipetolhuizen
James T Quirk wrote on 2021-06-16, 08:12:
This might be the case where the free disk space needs to be limited. There is a flag for that in MS ACT (GetDiskFreeSpace2GB).
Reply 159 of 306, by G-Stuff002
Tony Hawk's Pro Skater 2 (2000)
LAN Support
Retail, 1 CD
Checked on: Windows 7 X64
Problem:
When i trying to connect via LAN in the server-browser menu, (server is visible) the client hangs for a while (freez) , when the hangup passes, the server disappears from the list and appears again. But does not allow to connect (join) And everything goes on again
2.
Slave Zero (1999)
LAN Support. Has Multiplayer Patch but doesn't work for Windows 7 x64
Retail, 1 CD
LAN Patch: https://community.pcgamingwiki.com/files/file … ve-zero-update/
Direct3D Patch ( Works good ! ) : https://www.gamepressure.com/download.asp?ID=69355
Problem:
Can't find the server on the LAN. (server list is not visible)
LAN Server Browser is empty but two PC's on the same local network and are side by side
