First post, by ET
Hello
I recently bought a new computer with geforce 8500 / windows xp and DirectX 9.0c. The old one was also XP and DX 9.0c , but the video card was radeon 9250.
For some reason, when I switch to full screen , I get blur effect as if I choose "motion blur" filter. It is fine if I switch to surface output instead of ddraw.
The big problem is that it also happens with other emulators like mame and FCEU.
I looked into the Nvidia's control panel and Dxdiag, and couldn't find anything there about 2D image filter. Maybe it is connected to 3D somehow.
I also couldn't find any other posts with this problem. The blur effect is nice, but not as default!
can it be hard coded intro the driver?!
Reply 1 of 14, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
did you also get a new monitor (a TFT perhaps)? Because whenever these monitors switch away from their one and only resolution (for example 1028x1024), like when you are running a 640x480 Dosbox window fullscreen, it gets blurry. I hope someone can explain this better 😀
Edit: I really should read more closely, you wrote in the subject that it's the same LCD... No idea then, but you will probably have to fiddle around with the resolution, aspect and so on stuff in dosbox.conf.
Reply 2 of 14, by MiniMax
Rank Moderator
Moderator
It was better in the old days when LCD's were expensive. Then old people with bad eyesight could afford them: Problem solved.
_________________
Reply 3 of 14, by ErikGG
I read somewhere that DirectDraw has a built in filtering that makes it blurry. As it is a new device, try out OpenGL this should do the trick. This is a bit slower on some systems.
Als set the fullresolution in the conf file to 640x480 (best res for most TFTs)
Also try to set a scaler like Normal3x or something.
Erik.
Read the new FAQ.doc
Reply 4 of 14, by `Moe`
Actually, to get no filtering at all, you should set "fullresolution=0x0" (and hope that your desktop uses your LCD's native resolution. Then an output setting like "openglnb" can give you an absolutely unfiltered DOS experience 😉
Reply 5 of 14, by wd
Rank DOSBox Author
DOSBox Author
what is 0x0? Is that translated somehow or just the old define for =original?
Reply 6 of 14, by `Moe`
It is "use desktop resolution", even twice: DOSBox contains code to handle it as a special case, and according to the SDL API docs, that wouldn't even be neccessary, as width=0/height=0 is documented to use the "current" resolution anyways.
Reply 7 of 14, by ET
Sorry guys, I wasn't clear enough : I can solve the problem on Dosbox by trying other modes, but because I use other emulators , I want to know if I can fix it on the driver / control panel level.
I have some games on lowres that use directdraw (mega man x3) , and have no problem.
Maybe I should try the windows forum? although it's more emulation related.
EDIT: for some reason it's fine now, even with directdraw, and even MAME is ok. Only the FCEU nes emulator still have problems. However, it also happens on stretched window mode, so maybe it's not directdraw fault...
Reply 8 of 14, by MiniMax
Rank Moderator
Moderator
MOVED
_________________
Reply 9 of 14, by Sephiroth
Your "problem" is a feature of nVidia cards called "doublescan". When you run in low-resolutions the video-card doubles it in hardware for higher resolutions so that LCD monitors won't be trying to draw a single pixel using several physical pixels. Turn off doublescan and you will be back to normal, although on LCD monitors unless you are running in the native resolution or half the native resolution, expect distortion.
486 Launcher v2.0 is now under development!
Reply 10 of 14, by Davros
where is this double scan feature ive never seen it
ps: does selecting dont scale help ?
Reply 11 of 14, by gulikoza
Actually what it means is current video mode *or* desktop resolution if video mode is not set. So having a 640x480 SDL window (on some larger desktop) and trying to switch to fullscreen will change display mode to 640x480 😀. Too bad SDL does not have your SDL_GetDesktopMode 😉
http://www.si-gamer.net/gulikoza
Reply 12 of 14, by ripa
In NVidia's control panel under Display Mode Timing.
Reply 13 of 14, by keropi
I have a CRT monitor and get this blurring... so it is not tft only prob
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 14 of 14, by swaaye
might also want to try the LCD's scaling instead of the GPU's. You can choose between them in NV's control panel.
