First post, by Kelly Stiver
Hello - I've just installed Tachyon the Fringe (was released 2000 - 2001 by NovaLogic) on my netbook in VMWare Player under Windows 98SE guest. The game installed without a hitch, but when I clicked "start" on the game's startup menu to play-test it, I got a blue screen Fatal Exception message.
Why is this happening and how do I fix it?
I intend to play Tachyon The Fringe without 3D acceleration in my netbook.
Thanks in advance.
When I had the game installed on my old Dell Dimension 8200 (which I ordered brand-new in Nov. 2001) the game's graphics ran ok but sort of jerky, IIRC. My old Dell Dimension has Windows XP Home OS, and my netbook has Windows XP Home_sp3 as its host OS.
Reply 1 of 6, by Davros
To change to Software mode,
simply open up the Tachyon.cfg file with WordPad. Under the
[VIDEO]section, change USE_HARDWARE=1 to USE_HARDWARE=0,
why are you not playing it under xp ?
Reply 2 of 6, by DosFreak
Tachyon The Fringe (Demo)
Works fine for me on 2000, XP 32bit, 2003 32/64bit, Vista 32/64bit.
The only OS I had issue with was NT4 and there I had to use Zeckensack Glide Wrapper so perhaps you should try running it on the host with Zeckensack.
Make your games work offline
Reply 4 of 6, by Kelly Stiver
Thanks - am now trying to play-test Tachyon in my netbook's host Win XP (that is, until I get my joystick set up).
Here are images of 1) my "Tachyon.cfg" settings -
and 2) the tech report of the "this program encxounted an error...needs to close" error message (game proper never starts up - I get this error message instead) that I get when I click on "Play" in the game's menu (after I get to a window showing 2 screen shots side by side, the one on the left having green text on it, listed as "enabled" and the one on the right having no green text, listed as "disabled") -
When I click on the "video settings" a message pops up saying it's going to test the video, click "OK", so I click OK and I get a black screen.
Reply 5 of 6, by Davros
Tachyon works for me on xp
what gfx card do you have in your pc
edit I have tachyon set to win98 compatability
[LOCALE]
YES_KEY = Y
NO_KEY = N
[VIDEO]
WINDOWED=0
USE_HARDWARE=1
NO_VSYNC=0
RES=2
HW_TYPE=2
DEVICE=0
DEF_GAMMA=100
DEF_BRIGHT=70
[AUDIO]
DEVICE=0
A3D_DEVICE=6
RATE=2
A3D_CHANNELS=16
SFX_CHANNELS=16
[MULTI]
PORT=2766
VON_PORT=0
[JOYSTICK]
FORCE_FEEDBACK=1
[CONTROL]
INPUT = 0 ; 0-joystick, 1-mouse
MOUSE_DEADZONE = 1
MOUSE_SENSITIVITY = 8.0
RUDDER_SCALAR=1.0
[INGAME]
PAK_DISTANCE = 3.5
STAR_BLUR = 1
[MUSIC]
MENU_FILE = MENUBGS
MENU_SCRIPT_NAME = OPENING_BG
[GENERAL]
GAMEPLAYED=1
