First post, by Zaxxon
hi all i'm, having this problem with jedi knight and some other games of the late 90's,everytims i start them,both in compatibility mode or not,the colors and graphic appear all grabled.if i alt-tab to the desktop then comign back,in some games the graphics adjust itself for some wseconds,then reverting back to gabrled,whil in other games like jdi knight,it stil lremains that way.any help?
Reply 1 of 16, by DosFreak
Windows Vista (sometimes) & 7 (almost always) causes palette corruption with 8bit color games.
Best solution is to end the explorer.exe task before starting the games.
There are scripts out there with the appropriate commands if you want to create a batch file to do it.
Make your games work offline
Reply 3 of 16, by HeroZero
I had this same issue until I downloaded the ddraw viewport clear fix on this page: http://www.jkhub.net/project/show.php?projid= … ction=downloads
Works like a charm now.
EDIT: I'm on Windows 7 64-bit and I've also tried this on Windows Vista 64-bit with success.
Reply 4 of 16, by CrisGer
And you can get great advice in two places.. Massasi Temple, archive and forum of old Jedi Knight games and also on Lucasforums. both have good sources for all ithe info.
http://www.massassi.net/
Admin
3D Worlds and Game Developers Group Linkedin
http://3dworldandgamedevelopers.blogspot.com/
Reply 6 of 16, by CrisGer
The best way to play Jedi Knight is using the new JKE Jedi Knight Enhanced mod set up, it has been perfected thru long and careful work by community members and there is a enhanced texture project underway as well:
the JKE Jedi Knight Enhanced: JKE
Jedi Knight Retextured: JKR
JK Unofficial Patch:
and for the in game settings: these are reccomended for the best graphics, and I welcome any other suggestoins or other set ups that people find good:
1600 x 1200 Resolution (i use up to this)
3D Acceleration check Yes
Enter 32 in to Minmum Texture Size
Back Buffer In System Memory
Increase View Size to Maximum
Admin
Reply 7 of 16, by ADDiCT
I've recently played Dark Forces II: Jedi Knight in Win7 x64, and none of the fixes/updates I've tried got rid of the "garbled UI colors" problem on my system, though the game itself works quite well (and even supports widescreen resolutions correctly, which amazed me). The simple fix is to launch the game with the "-windowgui" parameter which makes the UI and videos run in a window. The 3D game engine will still run in fullscreen mode. It's not a perfect solution but it works.
Reply 8 of 16, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
@CrisGer: your links are not correct
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 9 of 16, by CrisGer
Now they are Dominus, sorry about that! Hello to Wein!
Admin
Reply 11 of 16, by CrisGer
I am sorry about that, my grandmother would be ashamed of me, she was from a small village near Villach.. i appologize for making Wien into Wein.
Admin
Reply 12 of 16, by Dominus
DOSBox Moderator
Thanks for the links (the site is a bit confusing IMO) and for all the Wein 😀
Reply 13 of 16, by thecrankyhermit
Here's a better solution. Before playing the game, right click the desktop, and open up the resolution control panel. Don't do anything with it - just leave it open. Then play the game. No more palette corruption.
Running:
Windows 10
Core i5-6600
Geforce GTX 970
8GB RAM
Reply 15 of 16, by thecrankyhermit
It's worked every single time I've tried it. And every time I recommend that to someone the response is always "Wow, I can't believe that worked!"
Certainly it at least makes sense for anyone with this problem to *try* the resolution control panel method first.
Running:
Windows 10
Core i5-6600
Geforce GTX 970
8GB RAM
Reply 16 of 16, by wizzel
Tried all of the above and i must say that ONLY ADDiCT's -windowgui switch hint works.
Don't know how all these patches and fixes from Jk Hub are supposed to work,
but they only corrupt the Jk.exe. So -windowgui works best.
The future of computation lies in emulation.
