First post, by Hatröss
I want to install the A3D Demos that come with the 2048 drivers here:
http://ftp.isu.edu.tw/pub/Hardware/multimedia … 048/index-e.htm
The drivers in that package install OK. I first tried to install using Audio Properties of the A3D tray program and then to the Demos tab. The disk rattles for a minute or so and that is that.
Next I click the Demos tab again it will again ask to install.
If I try to install manually by unpacking A3DDemos.exe and running setup this seems to work (file copy progress indicator) but at the end there is a message box with "severe" in it's title bar
and the text: "HTML documents failed to register". Again no demos become available under the tray program.
This has been done on a full, clean install of Win98SE. Also the wavetracing demo works (and sounds good to my ears) so that's why I think the drivers installed OK.
Does anyone know of a solution for this?
