First post, by Azurex
Hey all,
I'm aware that there is already a thread about this issue, however the problem was marked as 'solved' and I have followed similar steps, although they don't appear to work for me.
I've managed to install the game perfectly fine on Windows 7, and I have installed the 3.0 patch - Creative Labs setup selected too. The game launches and runs fine with no issues, despite the menu graphics being a little jumbled, but there is no music at all. Even with the ISO mounted, there's still no music present. I will note that I have already attempted reinstalling the game to C drive, and I have checked the registry values and what not.
Does anybody have a suggestion? I really want to play this game with music!
Reply 1 of 13, by Gamecollector
Are you sure your OEM version has CDA at all?
The retail version have 10 CDA tracks.
Reply 2 of 13, by Azurex
To be completely honest, I'm not 100% sure. Is there anything I should be looking for specifically? Here's the contents of the disk1 folder in the iso
I have searched the disc's contents quite a bit and I don't see anything indicating CDA files, or audio files in general for that matter.
I also noticed that the folder is titled 'disk1' ... Perhaps a second disc contains the music files? If so, I definitely don't have that.
Reply 4 of 13, by Azurex
Foobar doesn't recognize it as a media disc, and so ripping or playing options are unavailable. The same case with Winamp.
As far as I can see, there aren't any audio files on the disc outside of the game data sounds in the .cab files, presumably.
Reply 5 of 13, by ZellSF
The game uses CDDA. Your copy is faulty.
Reply 6 of 13, by collector
There is your problem. ISOs do not contain CDA tracks. Make a BIN/CUE pair of you original CD or just use your original disc to play the game.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 7 of 13, by Azurex
Despite this, when I launch the game via the disc itself, the music and everything works completely fine.
So, there is actually audio files. The only way I can get the game to work completely 100% is if I launch it through the disc. Is there any way around this?
Reply 8 of 13, by ZellSF
You need to actually respond to this and tell us if you're using a bin/cue or a iso. Because a iso will not work. Making sure you're using a bin/cue and not a iso is the first step.
We can't help your or magically guess what else is wrong before you do that first step.
Reply 9 of 13, by Azurex
A .ccd, .sub and .img file
I won't be able to rip the disc myself, as I no longer have access it. This is just a downloaded copy. The game runs fine with music if I launch it via the mounted disc itself.
Reply 10 of 13, by Gamecollector
Run the attached program and print the CDA track number here.
For both the original cd and the mounted cd-image.
    CDInfo.7z
    192.76 KiB
    61 downloads
Reply 11 of 13, by ZellSF
Azurex wrote:
A .ccd, .sub and .img file […]
So the problem is with your installation? Have you tried to see what it does if you start it without patching it?
Reply 12 of 13, by collector
Azurex wrote:
Abandonware is not supported here. You need to get a legal copy. I suspect that a mod will be locking this thread.
Reply 13 of 13, by Azurex
Ah, this helped! Thank you. The game works perfectly now. No issues!
collector wrote:
I understand that piracy may be against the rules, but I'm not asking where I can pirate it. I'm asking in hopes of finding a solution to a problem that anybody with the game could have - legitimately or otherwise.
However, by all means let this thread be locked, as my issue has been resolved 😉
