First post, by LoneKiller
Hi to all,
I am still trying to have You are Empty (2006 game) work on my PC. Game installs fine and all programs like OpenAl are installed perfectly. Here are my specs:
Intel Quad Core CPU 2.5Ghz
8GB RAM
ATI Radeon 5780 with 11.15 Drivers installed
SO Windows 7 Ultimate 64 bit
I can run the game if I select Windows XP Compatibility mode or disabling visual themes in the Compatibility tab of the exe (this is needed, or the game crashes immediately). Main menu is OK, I can setup the game and select New Game. After that the intro is played.
Immediately after the intro, the screen goes black, no audio is present and I have to Alt-Tab out of it.
I tried all possible compatibility modes, none is working. I also have the same effect by using VMWare with Windows XP installed so I do not htink it is connected to Win7, more probably to video drivers. Game is also Directx9 so DgVoodoo cannot help.
The game was perfect on my old Pentium4 with XP, but now I am running out of ideas....
Any suggestion is very appreciated.
Many thanks in advance.
Lone Killer
