First post, by marianoryu
I managed, back some years ago, to install Heavy Gear in Windows 10 64-bit thanks to this forum's help.
I had my machine upgraded, but in the process, my hard drive was wiped clean, so I have to install everything again.
Upon installing Heavy Gear (legal copy, patched successfully to 1.1. and 1.2., gameplay works well with dgVoodoo in Direct 3D display mode), I'm getting the cutscene videos (including the Activision intro movie) as blue squares, even though sound is working normally.
Any help will be most welcome!
Reply 4 of 25, by Dee-Dee
The game uses Indeo Video 5 for the movies and this codec is disabled by default on modern Windows systems.
Did you try enabling the codec from the command prompt with the command:
"regsvr32 ir50_32.dll"
Reply 5 of 25, by Dee-Dee
Discrete_BOB_058 wrote on 2020-08-30, 05:39:
The game crashes upon startup, did you use other fixes for it
Heavy Gear patched to v1.2 works fine here using DxWnd 2.05.54:
- Imported settings from "exports\Heavy Gear.dxw".
- Corrected path field to point where I have the game installed.
- Enabled Dxwnd options "Keep aspect ratio" and "Desktop work area".
Reply 6 of 25, by BEEN_Nath_58
Dee-Dee wrote on 2020-08-30, 09:58:
Heavy Gear patched to v1.2 works fine here using DxWnd 2.05.54: - Imported settings from "exports\Heavy Gear.dxw". - Corrected p […]
I used this and the game still crashed. I checked eventi viewer and the crashes had different fault modules, ntdll.dll msvcrt.dll.
Before this hgshell.dll of the game was the fault module. I dont have the Indeo files in my pc, so I am looking for a setup for it
I am installing all C++ Redist now
Reply 7 of 25, by BEEN_Nath_58
https://sourceforge.net/p/dxwnd/discussion/ge … hread/4fe82c35/
Check here, my country s sourceforge page is down
Btw I need a few files, msvcrt.dll and hgshell.dll of your game. Mine crashes
Reply 8 of 25, by marianoryu
My game started up just fine right out of the bat (Windows 10 Pro 64-bit, build 19041.450), patched up just fine to 1.1 and then 1.2, and works fine using dgVoodoo, without the need for DxWnd (I never could get the hang of that program). When in 3DFX display mode there are some black squares in dirt textures and explosions, but they work just fine under Direct3D mode.
My only problem are the blue cutscenes so far.
Here are the files of my game if you need them.
    Heavy Gear.zip
    915.12 KiB
    86 downloads
Reply 9 of 25, by marianoryu
Dee-Dee wrote on 2020-08-30, 09:55:
I did that from the K-Lite Codec Pack Tweak Tool, but the cutscene videos still show up as blue squares.
Reply 10 of 25, by BEEN_Nath_58
marianoryu wrote on 2020-08-30, 13:30:
I see differences in file sizes with one you provided even after I updated the game. Is my executable the problem?
ANyway DxWnd will work if you dont set the file as admin. DxWnd will run in dx mode not glide, it wont even use the dgvoodoo files.
Reply 12 of 25, by BEEN_Nath_58
marianoryu wrote on 2020-08-30, 15:59:
I'm not using DxWnd. Only dgVoodoo.
I was LoL the whole moment. I downloaed another mdf/mds and it worked. It works without dgVoodoo too. Did you check your CD video folder? I didnt have problem without dgVoodoo
Reply 15 of 25, by BEEN_Nath_58
marianoryu wrote on 2020-08-30, 17:33:
I don't think it has to do with dgVoodoo. I had it before in this same system, and it worked just fine.
Well I get the blue square box when using dgVoodoo. As soon as I remove the dgvoodoo dlls the video works fine. Doesn't the game work for you without dgVoodoo?
Reply 16 of 25, by marianoryu
Discrete_BOB_058 wrote on 2020-08-30, 18:19:
Now it's me who has the 🤣 expression - you're right! Direct3D seems to still be working fine though.
Reply 17 of 25, by ZellSF
Machine upgraded... how? Because if you were going from Nvidia to AMD, dgVoodoo doesn't like AMD in its current stable version and it could be that.
Discrete_BOB_058 has a Nvidia card so it's not that that. Still though, Heavy Gear 2 FMVs should work fine with dgVoodoo (they do here). So something changed.
marianoryu wrote on 2020-08-30, 13:47:
At the risk of going very off topic, you shouldn't install codec packs. They're unnecessary for 99% of people.
It will cause problems for other games. Though it isn't the problem here.
Reply 18 of 25, by marianoryu
ZellSF wrote on 2020-08-30, 20:17:
Machine upgraded... how? Because if you were going from Nvidia to AMD, dgVoodoo doesn't like AMD in its current stable version a […]
The biggest change would be the GPU. Previously it was a 750 Ti, now it's a 1660 Ti.
Reply 19 of 25, by BEEN_Nath_58
marianoryu wrote on 2020-08-30, 20:41:
did you try the game without dgvoodoo
