First post, by matthi321
hello i get the follow error when i try to save in a mission
tactics:fatal error
strange pointer:10EB50E0 type 8(building)
there may be further info in the file tactics.log
anybody know how to fix this?
tactics:fatal error
matthi321 wrote on 2020-11-23, 19:07:hello i get the follow error when i try to save in a mission […]
tactics:fatal error
there may be further info in the file tactics.loganybody know how to fix this?
Similar problems occur when you don't run with administrator privileges. Did you try running it as administrator?
Discrete_BOB_058 wrote on 2020-11-24, 05:09:matthi321 wrote on 2020-11-23, 19:07:hello i get the follow error when i try to save in a mission […]
tactics:fatal error
yep same error happened
It's a problem with certain versions of the fan patch and certain versions of Windows 10.
Either update to the latest fan patch, or just run the latest official patch.
