First post, by BEEN_Nath_58
On my PC, I want to index the names of files and folders in a particular location (say the files or folders at "D:\Backups\"), to a text file or any format. Which application should help me do it? I don't have any the name of a program which does this, or is there a Windows function for it?
Reply 2 of 3, by spiroyster
You can use dir command and pipe the output to a file.
Open command prompt, navigate to any dir, then type...
dir /b /s > filelist.txt
To get a list of all files, dirs and subdirs (and files) in a text file called filelist.txt.
See https://docs.microsoft.com/en-us/windows-serv … ws-commands/dir dir command docs for other switches such as file attributes etc. if you want to list that information too. Should even work in pre windows msdos (6.22 etc).
Reply 3 of 3, by BEEN_Nath_58
Boohyaka wrote on 2022-01-09, 10:03:
A simple PowerShell script will do what you want, for example:
get-childitem -path "d:\backups" -recurse | select-object FullName | export-csv "d:\index.csv"
spiroyster wrote on 2022-01-09, 10:53:
You can use dir command and pipe the output to a file. Open command prompt, navigate to any dir, then type... […]
Either of them worked fine, thanks. But is there a way, I can remove the full path and keep the file and folder's indexing.
For eg: I want "Folder X\xyz.txt" instead of "D:\Backups\Folder X\xyz.txt"
