First post, by darien174
trying to replay this great classic but everytime i execute the program the window pulls up and gives me this error message.
An privileged instruction was executed at address 00473f5.
Click ok to close application.
Reply 8 of 17, by HunterZ
Also this: http://www.sierragamers.com/bbs/BBSTopicPage.asp/t/5516/p/1
And in case that forum ever goes down:
myllyhouseATkotiDOTluukkuDOTcom You'll need to use the sierraw.exe executable copied from the cd into your kq7 folder rather th […]
You'll need to use the sierraw.exe executable copied from the cd into your kq7 folder rather than the sierraws.exe executable that is installed by default. Also, run in 256 color compatibility mode. If you want the game to run full screen, use run it from a batch file using Multires (free from www.entechtaiwan.com). Here's the batch file I use:
c:
cd multires
multires.exe /640,480,8 /exit
d:
start /w C:\SIERRA\KQ7\SIERRAW.EXE c:\SIERRA\KQ7\RESOURCE.WIN
c:
multires.exe /restore /exit
where my cdrom drive is d:, multires in installed on c: i the "Multires" folder, and the game is in the c:\sierra\kq7 folder. If you use the batch file, do not use use XP's own 256 color setting on the compatibility tab.
#26080
4/13/05 at 15:15
Let us know if it works...
Reply 9 of 17, by darien174
well using your first suggestion the game acted like it was going to load but then this came up.
"We're sorry, you have encountered an internal game error. Please restart your game and restore a saved game. If you have continued problems, please report the following information to Sierra Tech Support:
Error 99: Error loading resource 10.wav
I:\sys\sci\restype.cpp(56)
Script 15/$2cc
Reply 11 of 17, by darien174
i'm not real sure how the game can't be install correctly but i'll try it again just for the h*ll of it. also tried your second suggestion but it's confusing me a little. let me try uninstalling and reinstalling to see what happens.
Reply 12 of 17, by darien174
well reinstalling didn't help me out any still get the same error message. i copied the file from the cd and edited the shortcut settings. manually put windows into 256 color and it gives me the same message
Reply 14 of 17, by collector
Versions of this game earlier than 2 won't work on an NT system with the default executable, SIERRAWS.EXE and will give exactly the error that you first posted. The sad thing is that there is no DOS game on 1x versions of the game. Version 2 of the game runs well on XP AND has a DOS version.
The only thing that you need to do is delete SIERRAWS.EXE from your installed folder and copy SIERRAW.EXE from the CD and rename it to SIERRAWS.EXE. Then just set SIERRAWS.EXE to run in 256 colors and if you want, 640x480.
Reply 16 of 17, by collector
What version is your game? Look in the base directory of the CD for a file called VERSION and open it in Notepad.
