First post, by AlphaCen
Hi guys,
I'm searching for a Machines (Publisher: Acclaim) to run it on WinXP.
I found only dead links.
plz help.
cya Alpha
Reply 2 of 3, by AlphaCen
I still have the newest patch (1.15), but it doesn't work on WinXP.
I read something about a patch, which allowe to play on WinXP, but all the
links are broken. 🙁
cya Alpha
Edit.:
Can someone please move this thread to "Windows"? My mistake.
Reply 3 of 3, by LightningSt0rM
Hunter Z THANK YOU SO MUCH THANK YOU THANK YOU!! I've been looking for the real version(and I found it), but then I got a prob: Machines.exe not a valid win32 application(a nasty thing wich many gamers who want Machines back have to deal with), and I found patches to make Machines work on Win XP, and then a no cd crack, but I needed Machines GERMAN Update and you wouldn't know how much afternoons I've wasted looking for it, but then I finally saw your URL and I downloaded the GERMAN Patch, but now I get the win32 problem again, so I have to overpatch it back with the win2000 patch and the GERMAN Patch is the only way to make to no cd crack work, so if anybody knew a program to make 2 patches run at a same time, or can merge the 2 patches together, I would be VERY, VERY gratefull
