pcem directx 6 issue
First post, by tecker
I have this issue with pcem when emulating win 98, it runs fine but when I open a game like hot wheels stunt track driver it gives this error. I did install 3dfx tools and stuff so whats the problem?
Reply 1 of 23, by Gmlb256
Hello.
Which exact 3dfx driver did you install on the emulated computer? If it is the latest one from the Voodoo2, it requires DX7 to be installed.
Reply 2 of 23, by tecker
Gmlb256 wrote on 2023-01-20, 15:32:
Hello.
I think I downloaded voodoo 3 3000 agp
Reply 3 of 23, by tecker
tecker wrote on 2023-01-20, 16:27:
Hello.
here: https://archive.org/details/voodoo-3-3000-driver
do I need to download voodoo 2? if so, where can I find one?
Reply 4 of 23, by Gmlb256
tecker wrote on 2023-01-20, 16:33:
Hello.
That driver also requires DX7 installed as minimum to get DirectX applications working. Otherwise, I suggest replacing it with an older one that doesn't require it, and these can be found here.
No, it was an assumption because you didn't initially specify which 3dfx card was being emulated.
Reply 5 of 23, by tecker
Gmlb256 wrote on 2023-01-20, 16:40:
That driver also requires DX7 installed as minimum to get DirectX applications working. Otherwise, I suggest replacing it with a […]
sorry to bother but how do I replace the current voodoo 3 with the one you shown here? sorry I'm new to pcem, I want to replace the voodoo 3 directx 7 version with directx 6 verison
Reply 6 of 23, by tecker
tecker wrote on 2023-01-20, 16:51:
also for some reason, the hot wheels stunt track driver iso has directx 6 folder but I cant open since it will send me to this error that I showed before
Reply 7 of 23, by Gmlb256
No worries. 😉
To make life easier with the current drivers, the same archived site has several versions of DirectX available.
As for replacing the drivers, do the following:
  1. Uninstall the 3dfx Tools in Add/Remove Programs.
  2. Go to Device Manager and remove the Voodoo3 there.
  3. Restart the emulated computer.
  4. The Voodoo3 will get detected once again, cancel the Found New Hardware Wizard dialog when it appears.
  5. Run the installer that comes with the older driver.
Reply 8 of 23, by tecker
Gmlb256 wrote on 2023-01-20, 17:04:
No worries. ;) […]
No worries. 😉
hey how do I put directx 6 from the link to the running win 98?, because when I downloaded it, it gave me a zip, do I have to extract it?
Reply 9 of 23, by Gmlb256
Extract the contents from the zip file, create an ISO image from the extracted files and from there you can mount it in PCem.
Reply 11 of 23, by Gmlb256
tecker wrote on 2023-01-20, 20:19:
Gmlb256 wrote on 2023-01-20, 17:32:
how do I do it? do I need imgburn?
Yes, ImgBurn or a similar program is enough for creating a simple ISO image.
Reply 12 of 23, by tecker
Gmlb256 wrote on 2023-01-20, 20:37:
is it required for it to be a bootable image?
Reply 13 of 23, by Gmlb256
tecker wrote on 2023-01-20, 20:43:
No.
Reply 14 of 23, by tecker
Gmlb256 wrote on 2023-01-20, 20:46:
No.
it should look like this?
21.94 KiB
btw I downloaded this version of voodoo 3 so it should possibly come with DirectX 6 right?
12.06 KiB
Reply 15 of 23, by Gmlb256
tecker wrote on 2023-01-20, 21:00:
No.
Yes, but the format should be ISO.
The driver doesn't come bundled with the DirectX redistributable, but that should already be installed on the emulated computer. Besides, the last one that doesn't require DX7 is dated 21 Oct 1999.
Reply 16 of 23, by tecker
Gmlb256 wrote on 2023-01-20, 21:10:
Yes, but the format should be ISO. […]
No.
like this?
60.3 KiB
hm. so do these 2 come with DirectX 6 redistributable? or do all of them don't come with redistributed DirectX 6?
19.65 KiB
so if I downloaded this one on emulated win 98, it will install DirectX 6, or do I have to install DirectX 6 manually?
12.06 KiB
sorry for being annoying
also I accidently deleted the emulated win 98, now I have to start the whole setup again
Reply 17 of 23, by eddman
Don't make things so hard for yourself. If you read the readme of the driver you downloaded from archive.org, it says the version is 1.07.00, and it needs DX7.
Simply download DX7.0 or DX7.0a, put it in an ISO file, open it in PCem and install it.
No need to mess around with older drivers, specially a super old one like 1.00.
EDIT:
These drivers do not come with DX included. That text simply means which version of DX is required.
You haven't mentioned which exact 98 you're using. If it's 98 SE, it already comes with DX6.1a.
Reply 18 of 23, by Gmlb256
tecker wrote on 2023-01-20, 21:32:
like this?
Yes.
None of them come with the redistributable, just only the driver.
If it is the Windows 98 SE, it will come with DX6 installed already.
eddman wrote on 2023-01-20, 21:36:
Don't make things so hard for yourself. If you read the readme of the driver you downloaded from archive.org, it says it needs DX7.
Indeed, this is the first thing that I said to the OP regarding the drivers he originally installed. That should be easily understandable to everyone.
Reply 19 of 23, by tecker
Don't make things so hard for yourself. If you read the readme of the driver you downloaded from archive.org, it says the versio […]
EDIT:
I'm using win98 se oem full version
