DotXT
First post, by folkert
To get to know C# a bit I decided to implement an IBM PC emulator (the 5150 system).
So far it goes through bios up to the point of floppy disk access:
DotXT, (C) 2023 by Folkert van Heusden
Released in the public domain
301
016 KB OK
032 KB OK
048 KB OK
064 KB OK
601
ERROR. (RESUME = "F1" KEY)
INT NR 16, AH: 00
^C
I develop it under Linux but, being C# it will probably run on windows as well.
https://github.com/folkertvanheusden/DotXT
my emulators can be found at: https://vanheusden.com/emulation/
Reply 1 of 8, by Jo22
Hi. Could it be the BIOS?
IBM didn't had a lucky hand for writing firmware software, I think. 😒
I'm thinking of the mess they created with PS/2 series (individual reference diskette needed for each PC) or the 8 MHz speed limit that was hard-coded into some AT BIOSes.
Or its lack for type 47 fixed-disks.
Another user here has trouble with the PC BIOS, too, maybe.
The floppy controller wouldn't work with a Gotek, because BIOS/FDC hold a pin low for too long. Not sure it's really related, though.
Unable to boot IBM PC (5150) with a Gotek emulator and FlashFloppy
Reply 2 of 8, by GloriousCow
Jo22 wrote on 2023-06-17, 13:50:
Happy user of a Gotek on an IBM 5150 here 😀
MartyPC: A cycle-accurate IBM PC/XT emulator | web version: https://martypc.net | https://github.com/dbalsom/martypc
Reply 3 of 8, by xcomcmdr
A new PC emulator in C# ? Very cool ! 😀
C# is a great choice for any project. Especially since it is cross platform (any .NET project will run on Windows, macOS, and Linux).
Also, perhaps an example of other emulators in C# will help you both discover C# and write your own emulator. Here is an example:
https://github.com/OpenRakis/Spice86
Also this one:
https://github.com/gregdivis/Aeon
https://github.com/maximilien-noal/Aeon-Stagi … e/feature/xplat
(this fork runs on Linux and MacOS thansk to AvaloniaUI. The original depends on Windows).
Since C# has a lot of low-level features inspired by C++ (pointers, safe pointers with Span<T> or Memory<T>, structs, value types, unions, enums, flags, etc...) rather than Java, the code from 86Box, PCem, and DOSBox Staging can help too.
If you want to learn C#, I'd recommend the book C# in Depth.
Reply 4 of 8, by Jo22
^That's interesting!
Just found an interesting news from 2 years ago.
Microsoft Opens Up Old Win32 APIs to C# and Rust, More Languages to Come
https://visualstudiomagazine.com/articles/202 … 2-apis.aspx?m=1
I wonder if this will also cover those classic APIs used/supported by Win32s. ^^
Reply 5 of 8, by xcomcmdr
I love Windows 3.11 with Win32S. I wish I could targer it with C# (although someone already did). 😁
Going the other way, there is a project to compile C# to native code for IBM PC computers: https://github.com/CosmosOS/IL2CPU
It uses this project, a high level assembler for X86 and X86_64 assembly: https://www.x-sharp.net/
The mainline .NET SDK already supports ahead of time compilation to native code (skipping the bytecode, and therefore the JIT compilation), but of course not for such a low level platform. 😁
@folkert:
You could try to run this BIOS: https://github.com/skiselev/8088_bios
Reply 7 of 8, by xcomcmdr
This BIOS looks very fine indeed ! This will help a lot for anyone trying to emulate a BIOS in a high level language.
Reply 8 of 8, by Jo22
GloriousCow wrote on 2023-06-17, 15:54:
I'm a big fan of GLaBIOS too https://github.com/640-KB/GLaBIOS/ […]
xcomcmdr wrote on 2023-06-17, 15:53:
Hm. Looks good. 😀 👍
Even has 736KB Coventional Memory support out-of-box.
