First post, by MusicallyInspired
Just bought a used P2 from a rummage sale and tried putting one of my 40GB HDs in it. No matter what jumper setting or BIOS setting I use the BIOS will just NOT detect it. When it seems it's on the right setting the autodetect just loads on forever until I restart. I know the HD is good because it was just working fine yesterday in my other computer.
Is maybe a BIOS update needed or something? Where would I get that sort of thing and how would I know what BIOS type/version I have?
Yamaha FB-01/IMFC SCI tools thread
My Github
Roland SC-55 Music Packs - Duke Nukem 3D, Doom, and more.
Reply 1 of 10, by Zup
Check if there's a BIOSE update. If this doesn't work, your HDD may have a jumper that limits it's capacity to 32 Gb, so it works in old mainboards.
I'm selling some stuff!
Reply 2 of 10, by Riboflavin
Ha! Yeah. I have the same problem. Same computer specs. I've been dealing with it for years now.
Still haven't found a BIOS update.
But that might change. Necessity is the mother of invention... just ordered several new P3 processors in the mail, so I might HAVE to update the BIOS because these are coppermine processors, and the motherboard doesn't support them with it's onboard BIOS.
But I digress..
Yes.. if you have a hard-drive limit jumper, you can do that. That's your best bet actually. You are probably stuck at 32 gigs just like me.
Otherwise you can try to find a BIOS update. Look for serial numbers, model numbers etched on your motherboard, and any strings of odd sequences of letters/numbers in your BIOS settings and googlesearch googlesearch googlesearch. Good luck!
-riboflavin
**Don't forget to enjoy the sauce**
Reply 3 of 10, by cdoublejj
Here is a site to check out http://www.wimsbios.com/index.jsp go to the forums they know quite a bit about bios even about modifying it but all you can mod as far as i know is the energy start icon bios displays when the system boots up
Reply 4 of 10, by dh4rm4
There are also ways around the limit with software hacks of the bootsector. Check with hard drive manufacturer websites, like Westerndigital.com (or whoever made your drives) for a setup disk (image file for booting from floppy or CD). This will allow you to set the drive up for use in a BIOS limited system.
Reply 6 of 10, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
That IDE card should have its own BIOS then though.
1+1=10
Reply 7 of 10, by swaaye
cheap Promise Ultra 100. I had a Promise SATA150 TX2 in a 486 once. Fun to see a 486 with a SATA HDD 🤣.
Reply 8 of 10, by collector
I'm not sure if I have even seen a modern one that didn't.
Reply 9 of 10, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
There's also www.rom.by , a site with unofficial BIOS patchers. Fixes some of the disk size bugs. At your own risk.
http://rom.by/english.html
Reply 10 of 10, by MusicallyInspired
I know this is an old thread but I'd just like to say thank you to everyone who replied. I managed to find a BIOS update for my motherboard (which was an Elite-P6BA-A+....bloody hard to find) that allowed it to accept up to 128GB drives. So now it's detecting the 40GB and all is well. Thanks a lot, guys. Couldn't have done it without your links!
My Github
