First post, by gerpux
Hello! Given there's DosBox support, how hard it would be emulating the IBM PS/1 Audio Card in PicoGUS (github.com/polpo/picogus)
It already has Tandy emulation. Currently it can emulate:
- Gravis Ultrasound (GUS) - the primary focus of PicoGUS, hence the name
- Sound Blaster 2.0 / AdLib (OPL2)
- MPU-401 (with intelligent mode) - outputs MIDI data on 3.5mm MIDI TRS connector
- Tandy 3-voice
- CMS/Game Blaster
Anybody tried? Or is interested?
Reply 2 of 10, by jal
If Tandy is emulated, PS/1 should be easy to do. But since there's so little support for the PS/1, I'm not sure what the use would be.
Reply 3 of 10, by gerpux
jal wrote on 2024-04-16, 10:13:
Just nostalgia (and adding one more sound card to the supported list, the more the merrier).
With regards to usefulness an awesome addition to PicoGUS would be SB AWE 32/64 support.
Thanks jal
Reply 4 of 10, by jal
Not sure if AWE 32/64 support is doable. Perhaps 32, but recall that the "64" was just 32 + the other 32 in the Windows driver, so for DOS games it's useless. I think the feature set of AWE 32 already exceeded that of the GUS, but it supports both wavetable and OPL3, and I don't think a RP2040 is capable enough to emulate both (it already struggles with OPL3 alone, I've read).
Reply 5 of 10, by gerpux
jal wrote on 2024-04-16, 15:43:
Gotcha. And what do you think about emulating SB Pro and SB16? Should be doable I think
Reply 6 of 10, by jal
Well, they're 16-bit cards, and the PicoGUS is 8-bit. Come to think of it, that would also prohibit proper AWE emulation. Not sure why the didn't opt for a 16-bit ISA card, perhaps it's the limit to the number of the RP2040's GPIO pins.
Reply 7 of 10, by gerpux
jal wrote on 2024-04-16, 15:50:
That's right, it's an 8 bit ISA port but SB Pro for example I tested in such a port with decent results on the OPL functionality. I'm not sure about all the limitations of running an SB Pro (for example) in an 8 bit ISA port.
Reply 8 of 10, by jal
As Wikipedia writes, "The Sound Blaster Pro cards are basically 8-bit ISA cards, they use only the lower 8 data bits of the ISA bus. While at first glance it appears to be a 16-bit ISA card, it does not have 'fingers' for data transfer on the higher "AT" portion of the bus connector. It uses the 16-bit extension to the ISA bus to provide the user with an additional choice for an IRQ (10) and DMA (0)m channel only found on the 16-bit portion of the edge connector."
So the SB Pro uses just 8 bits for communication with the host. It could only play 8-bit samples. That's different from the SB16 and onwards, that could play 16-bit samples.
Reply 9 of 10, by gerpux
jal wrote on 2024-04-17, 14:24:
Ok great info! Thx jal
Reply 10 of 10, by jal
You're most welcome 😀.
