First post, by retro games 100
- l33t
I have tested three awe32 cards:
CT2760 (non-PnP)
CT3980 (PnP)
CT3990 (PnP)
For the two PnP models, despite hours of testing, I have never managed to get either of them to work correctly in the (free downloable demo) "Shadow Warrior" sound setup program. The part that will not work correctly is the AWE32 music testing section. When you use this sound setup program to test the AWE32 music, the music output has missing notes.
Please can someone else test this just to make sure it is nothing that I am doing wrong? Thank you very much.
Please note that this problem doesn't seem to occur if you use a non-PnP model, such as the CT2760.
Also, one other thing that I noticed was the CT3980 seemed to sound better than the CT3990. It was as if the bass sounded richer/deeper on the CT3980 than it did on the CT3990.
Best regards, Robert.
