First post, by manic232
I have a Gravis Gamepad Pro (Gameport version not USB). I am trying top get it working in Windows 98 SE, but am having problems.
If I go and add the gamepad in the control panel, it shows it as OK under status, but when I click on properties to test it all hell breaks loose!
I seems as if the buttons are bring pressed randomly and also the d pad is constantly moving and behaving very erraticly.
I have tried to calibrate the pad, but this does not work. I also tried adding it manually by adding a custom controller and choosing 4 button controller, 2 axis, but no luck.
I have tried googling this issue, but cant find much about it. Any ideas? Thanks.
Reply 1 of 3, by leileilol
Did you switch it from GrIP mode on the back?
Reply 2 of 3, by manic232
DOH!! thanks, what a total numpty I am, thanks that worked. but it's only showing 4 buttons, the pro has 10, do i need special drivers or something?
