PCEm. Another PC emulator.
Reply 160 of 1046, by SA1988
this emulator is really great, but it still has issues when displaying the boot screens of Windows 1.x and Windows 2.x in EGA/VGA/SVGA (640x200 16 color mode), whereas MESS hasn't and I think I found out where the issue is in the source code, but I'm not sure.
Reply 161 of 1046, by justincase
@SA1988
Where in the source code is the issue?
Reply 162 of 1046, by SA1988
justincase wrote:
@SA1988
it's probably in vid_svga_render.c, but I'm still not sure where it is exactly, I can only suspect that it is there.
Reply 163 of 1046, by SarahWalker
Stiletto wrote:
I have a knack for finding stuff like that. Is there anything else you are looking for?
Off the top of my head :
* UM8881F datasheet
* ALI1429 datasheet
* Gravis GF1 datasheet, if such a thing exists. Mainly to fill in the missing gaps between the GUS SDK and the Interwave datasheet
* Any documentation on the IDT C6/Winchip family which includes instruction timings.
* Anything giving PCI config registers for Trident TGUI-9440 and ATI 88800GX (Mach64),
Likewise, if there are any datasheets you struggled to find but eventually found while working on PCem, would you mind sharing them?
I don't have that much I think, probably nothing that isn't easily available :
* Analog Devices AD1418K
* Intel i430VX
* S3 ViRGE
* SiS496/497 (as mentioned somewhere above)
* Tseng Labs ET4000/w32i and ET4000/w32p
* Yamaha YM3812 and YMF262
Reply 164 of 1046, by leileilol
I've noticed the SB Awe32 emulation makes PCem exit on startup. Is it a commit error or is it just rudimentary at this point?
Reply 165 of 1046, by SarahWalker
It means you need a 1mb AWE32 ROM dump at roms\AWE32.RAW. There isn't a proper error message because I haven't yet figured out how to deal with sound cards needing ROMs (though it should put an error message in pclog.txt). It should work if you have the dump though, albeit only in DOS/Win3.x at the moment.
Reply 166 of 1046, by kekko
AWE32 emulation encouraged me to give this emulator a try.
after built and setted up everything, I noticed I can't find the rom dump I remember I had on my hdd many years ago.
this sound card is a piece of history in my youth.
no hope to get that rom in another way?
Reply 167 of 1046, by leileilol
Not even that one 1MGM.sf2 alleged "AWE32 Rom Dump" soundfont works?
Reply 168 of 1046, by SarahWalker
Won't work, has to be a raw ROM dump.
Reply 169 of 1046, by leileilol
Ah. Is there a way that I can dump my AWE32?
Reply 170 of 1046, by F2bnp
I can dump mine, how can I do it?
Reply 172 of 1046, by SarahWalker
I'm pretty sure AWE-DUMP is what I used.
Reply 173 of 1046, by leileilol
Okay, dumped my AWE32. CRC C8DA1E9E.
Reply 174 of 1046, by Yamato
Is there going to be pcem 0.8? If not, can someone help me compile pcem from source code?
Also i have problem with EGA. PCem beeps but doesnt give any screen output and crashes.Please help
Thanks in advance
Reply 175 of 1046, by leileilol
The Win95 drivers for AWE32 don't function, correct?
Reply 176 of 1046, by SarahWalker
Correct - AWE32 is DOS and Win 3.x only at the moment.
Reply 177 of 1046, by leileilol
For me, CTCM doesn't seem to detect and initialize, and AWEUTIL doesn't either. Using AWE64 CD driver install (which does work with an actual AWE32 including the WaveSynth crap). Could it be my rom dump?
Reply 178 of 1046, by SarahWalker
Looks like I have more testing to do. It definitely does work with the "AWE32 Installation Disks - DOS/WIN3.11" drivers in the VOGONS library.
Reply 179 of 1046, by SarahWalker
Just uploaded a fix for the DOS drivers on the AWE64 CD. The installed Win3.x EMU8000 drivers don't seem to work - do they work with a real AWE32?
