PCEm. Another PC emulator.
Reply 440 of 1046, by HalfMinute
Packed ScreamTracker 3 issue is fixed in last revision. Great job, Sarah. Looks like it should fix a whole bunch of stuff.
On that note, I just disabled emm386 and tested Fast Tracker 2. And PC speaker works fine . With enabled emm386 it hangs emulator. So can you please check FT2 with emm386 enabled ? It might be a similar problem, that you couldn't reproduce because of it.
Reply 441 of 1046, by HalfMinute
The Incredible Machine 1. Problem with gfx. The bottom part is wrong and blinking, I saw it in a few other games as well, but here its the most obvious.
EDIT: Attachment deleted. Do NOT post copyrighted software here.
Reply 442 of 1046, by SarahWalker
Still can't reproduce the FT2 issue, even with EMM386 loaded. More details about your setup please.
Reply 443 of 1046, by HalfMinute
Regarding FT2. Host processor Core 2 Quad 6600 2.4Ghz. I guess its some timing issue. Another thing, for some reason when you setup soundblaster alongside GUS in FT2, GUS is sounds considerably louder. Maybe its supposed to be that way, i don't know. FT2 doesn't work properly in DOSbox, so i have nothing to test against.
Incredible machine 1 is fixed, nice! There is a similar problem with Dangerous Dave 2, which is not completely fixed. Its abit harder to reproduce, screen starts blinking after you jump a few times in the start.
Reply 444 of 1046, by SarahWalker
I meant the setup in PCem. I don't really care what your host machine is.
Reply 445 of 1046, by SA1988
About the cdaudio problem I have talked about earlier, here it is:
Hope it can be fixed as soon as possible.
from 00:00, it goes directly to 05:54 skipping the other seconds.
Reply 446 of 1046, by HalfMinute
I've removed soundblaster and gus from setup, to make it cleaner. This way FT2 defaults to PC speaker and mouse pointer hangs right after start up. Without emm its working fine.
Attached autoexec.bat and config.sys just in case. Using ctmouse.exe as mouse driver.
Reply 447 of 1046, by SA1988
I have noticed that MS (not IBM) OS/2 1.0, 1.1 and 1.2 (not 1.21) don't work properly, same for IBM OS/2 2.0, which resets itself after inserting disk 1 in the setup prompt.
Reply 448 of 1046, by SA1988
24bit/32bit color has some minor glitches in the right side of the desktop on Windows 3.1x and Windows 9x (ATI Mach64GX)
Reply 449 of 1046, by Windows95Fan
PCem should not use the host RTC as base time and date anymore because most betas of operating systems require changing the BIOS time and date.
Reply 450 of 1046, by SA1988
some beta builds, notably 1500 of Win98, makes the emulator die for some reason when finishing setup (shortly before you get to the timezone config).
Reply 451 of 1046, by leileilol
Betas.
Reply 452 of 1046, by Alegend45
With the stock drivers for both S3 Trio64 and S3 ViRGE on Windows 95 OSR2, I can't get dxdiag to run tests on DirectDraw or Direct3D! DirectDrawCreate() fails with HRESULT = 0x88760231
Reply 453 of 1046, by SA1988
Alegend45, for some reason, 1024x768x32bit (same for 1280x1024x256) isn't available in the S3 on PCem and 1600x1200 has the mouse a bit busted.
Reply 454 of 1046, by SarahWalker
Which S3? There are three different S3 chips/boards emulated now.
Reply 455 of 1046, by SA1988
S3 Trio64 (N9) and Vision864 (Paradise)
EDIT: the mouse pointer in the S3 Virge in 1024x768x32bit looks strange.
Reply 456 of 1046, by SarahWalker
1024x768x32 isn't available on the Vision864 or Trio64 as those cards don't have enough memory bandwidth to implement it.
Reply 457 of 1046, by SA1988
thanks for these fixes and info Sarah.
Well, 1024x768x32bit, 1152x864x32bit (Mach64 GX only), on windows 3.1x or 9x, show some mess in the right side of the desktop, here's an example:
Reply 458 of 1046, by SA1988
the DOS/V problem isn't fixed yet, but the OS works fine with /HS=ON but not without any parameters in jdisp.sys.
Considering that DOS/V 6.20 has the default setting in config.sys after it is installed, the part about the scrolling should be documented, so, is it possible to fix it too?
Reply 459 of 1046, by Battler
It defintiely is, the original Windows 3.1 drivers for it list the mode, as does Windows 9x when you install the included S3 Trio64 driver. True though, by default it was sold with 2 MB VRAM or less, and therefore did not support that mode, but it was upgradable up to 4 MB VRAM, and at 4 MB VRAM it definitely supported that mode. The fact the VESA mode list returned by the BIOS, as well as the drivers themselves, all list his mode, clearly tells me the mode is supported.
Edit: FPM DRAM or EDO DRAM, not VRAM.
I also second the request to fix the problem with DOS/V (Japanese DOS). Basically, when JDISP.SYS (the DBCS display driver) is run in the default configuration (that is, without parameters), PCem shows a black screen. I think that's because it uses a 640x475 mode (since it uses a 8x19 font for the single-byte SBCS characters) that PCem doesn't recognize. Therefore, it seems PCem's hardware scrolling doesn't work well in that mode.
