Winevdm
First post, by crazyc
I've stumbled on this thing https://github.com/otya128/winevdm which combines wine's win16 dlls with mame's [23]86 emulation. I haven't tried it though.
Reply 1 of 100, by Jo22
Wow, thanks! I've just tried, but my Athlon 64 w/ Win7 is too, old perhaps.
The program just hung when I tried. Anyway, maybe I also did something wrong.
The language is in Korean, it seems. Using Google Translator in auto mode failed.
Here's the translation to English.
Reply 2 of 100, by collector
It actually works, if not completely. Here is Paintbrush from Win3.1 Running on my Win7 Pro x64.
    34.2 KiB
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 3 of 100, by NJRoadfan
Runs quite a few of the Windows Entertainment Pack games without a problem, including Chip's Challenge (no music though). Some like Jezzball crash and burn pretty good too.
Reply 4 of 100, by Jo22
Thanks for the feedback, guys!
Say, please, how did you make it run ? I'm curious! 😁
I did extract otvdm-v0.2.zip, changend to that folder and ran "CMD" in the address bar which gave a command line window.
Then, I ran otvdm.exe together with a Win16 program : otvdm calc.exe
After that, the command line window just hung. Nothing.
EditI I'm using Windows 7 x64 on an Athlon 64 X2 PC.
Reply 6 of 100, by Jo22
NJRoadfan wrote:
otvdm.exe --app-name your.exe
Ok, just tried again. It works now. I used drag&drop this time (dragged calc.exe onto otvdm binary). 😀
    26.71 KiB
Reply 8 of 100, by Jo22
Thanks, man! Do you know if it runs Win2 games properly now ?
In another thread, danoon improved his Boxedwine by using newer code.
This also helped to properly emulate klotz, a Win3-aware Windows 2.x game.
The menu bar became visible, for example.
Reply 10 of 100, by collector
Sim Tower. I had to create "WINDOWS\SYSTEM" subdirectories in the otvdm folder to copy WAVMIX16.DLL and WAVEMIX.INI to get it to run. Seemed to run well, if not a bit too fast for the few minutes I played it.
    83.85 KiB
Reply 12 of 100, by collector
Which is included with WineVDM. The WAVEMIX.INI from the CD should go in a WINDOWS subdirectory inside of your WineVDM directory and WAVMIX16.DLL from the CD inside of a "SYSTEM" folder under that WINDOWS folder. I should do an installer for Sim Tower.
Reply 13 of 100, by NJRoadfan
The installer actually runs in WineVDM (needs lzexpand.dll in its SYSTEM directory even though one is provided), gives me path errors after prompting for an install location though.
Reply 14 of 100, by Expack3
You can always manually copy the game files, conveniently contained in a folder called "SIMTOWER" on the disc, to your hard drive and try running the game that way. That's what I've done in the past (albeit without using Wnevdm).
Reply 15 of 100, by NJRoadfan
My 1.0 release CD doesn't have the uncompressed copies on it. I got it installed anyway. Runs but crashes trying to save or load a game file. The VDM has significant overhead. SimTower runs like its on a 486 on a Core2Duo.
Reply 16 of 100, by Jo22
The newer releases of Comet Busters! also used WinG and the WaveMix thingy.
(The original version used plain GDI and ran on my old 286!)
http://www.win3game.com/
Reply 17 of 100, by NJRoadfan
DosFreak wrote:
Grab the latest build linked on the site. It fixes crashing with commdlg calls. SimTower can now save/load cities!
Reply 18 of 100, by Jo22
Thanks for that piece of information! By the way, there had been some progress of the project's github site.
The newest build (debug117) adds wheel mouse support, if I understand correctly.
https://ci.appveyor.com/project/otya128/winev … build/artifacts
Reply 19 of 100, by filipetolhuizen
Congrats to all of you who are putting so much effort on these VMs! This is exactly what we needed for x64 versions of Windows. Now I'll finally be able to switch and keep those games running without setting up a whole sepparate VM for them.
