First post, by lam
I've tried to install windows 1.0 and windows 2.0 on dosbox in these days.But It can't works!I'd like to play the ancient old classic games of windows.How can I install them in dosbox????
You can't.
windows 1.0 and 2.0 are not supported by DOSBox
Water flows down the stream
What ancient old classic games of Windows are you talking about?
The only games I know of, other than any bundled with the operating system, are Balance of Power and Balance of Power: 1990 edition. They run on Windows pre-3.0 or come with the Windows runtime when used in DOS.
It is noted at http://toastytech.com/guis/misc.html that programs intended for older versions of Windows can be persuaded to run under Win 3.x and later with relative ease.
