what key to increase or decrease speed in Linux
First post, by pcuser4
I installed DOSbox for Mandriva 2006. I tried to press ctrl+F8 or F12 key to increase/decrease speed but speed is not increased / decreased. Need HELP!
Thanks!
Jack
Reply 1 of 1, by MiniMax
Rank Moderator
Moderator
Did you try to read the README.txt file that comes with DOSBox?
Did you try the command INTRO as it says on the DOSBox when you start DOSBox?
_________________
