Useful links:
Ensoniq FTP mirror
EMU's Ensoniq downloads (final drivers)
There are some very useful txt files in that FTP . Guides.
If you change the card from its default jumpers, the driver installer usually won't set the drivers up correctly. The installer apparently isn't able to detect the port addresses. The Windows drivers can be reconfigured in the Device Manager; just turn off auto-detect and set the resources to the proper jumper settings. IRQ and DMA are fully software-configurable and can be set to whatever open resources you have.
The DOS drivers read a sndscape.ini that is within the Windows dir and set by Windows. So when you set it up in Windows, it should then work in DOS too.
C:\SNDSCAPE is where the DOS drivers get stored. They do access a few files in the Windows directory, like I said. The INI file and the sndscape.co* firmware files. Within the DOS folder should be a INITSS.BAT file that will set a BLASTER environment var, SNDSCAPE var, and run SSINIT /I. SSINIT is the dos Soundscape configure program and will let you set resources, enable/disable a few hardware features, and edit the mixer settings.
The SNDSCAPE environment variable is what SSINIT uses to find the SNDSCAPE.INI and SNDSCAPE.CO* firmware files. You can setup a Windows-independent DOS config by copying those files to the folder with SSINIT and then changing SET SNDSCAPE to that dir.
BTW, a Soundscape without the daughtercard is a regular Soundscape S-2000 or Soundscape II. The only differences between an Elite and a regular Soundscape are the ESP DB and a different 2MB patch set. If you have the headers for the ESP DB, that's sorta odd....perhaps the prior owner removed the ESP for some reason. I don't know for sure though if the later Soundscape boards were just Elites without the DB attached. An Elite will work without the DB but you obviously lose the DSP effects.
I may have an extra ESP DB, btw. 😀 I'll check later. I used to have a broken Elite but I would think the ESP is fine.
Doom doesn't have native Soundscape support. You will need to use Sound Blaster 2.0 (mono 8-bit) as digital audio and General MIDI as music. Sndscape's SB emulation isn't really all that great. I'd suggest a SBPRO or SB16 be alongside it. Though this can be a configuration headache.[/url]
