Reply 600 of 1046, by ppgrainbow
- Member
wrote:wrote:wrote:small fix: added support for the 8Mhz model of the IBM AT.
I have failed once again at putting the ne2000 support on PCem 🙁Oh dear, can you explain to me why isn't NE2000 working properly in PCem? 🙁
It's probably hard to do. I know Qemu (GPL & BSD) & Bochs (GPL) both have NE2000, so if I were going to just going to try to mash code, that is where I'd start. Although it doesn't mean any of it will work.
But I haven't programmed anything real in so long that I'm just sitting in the gallery I guess.
That's what I've been thinking. I'm currently running Windows 95 under Qemu 0.9.0 and I got the net working. I couldn't even install Windows 95 under Qemu 2.0 due to errors preventing Windows 95 Setup from progressing properly.
