First post, by yamann777
I'm trying to use DOSBox to allow SpinRite to fix a USB voice recorder with deleted files and bad sectors on it. Downloaded DOSBox, ran it, mounted the USB drive, mounted the CDROM with SpinRite on it and ran SpinRite. That worked. Both drives were DIR available accurately. Started SpinRite. It saw the USB, selected for repair, then locked up. Gonna need help with this one. Any consideration you can provide is greatly appreciated!
Yamann777
Reply 2 of 4, by Snover
SpinRite can’t do that either, since its recovery relies on the physical properties of magnetic media. Recovery of flash media is impossible if the memory gates are damaged.
Yes, it’s my fault.
Reply 3 of 4, by Miki Maus
Two points (taken from Wikipedia):
SpinRite may be run from a bootable floppy disk, USB flash drive or CD-ROM on a PC-compatible computer, independent of the operating system installed on the host computer.
SpinRite tests the data surfaces of read-write magnetic disks including IDE, SATA, USB, floppy, ZIP and others.
Reply 4 of 4, by Snover
You are highlighting the wrong part.
Yes, it’s my fault.
