First post, by tricapwr
after successfully installing DOS BOX I get the following message:
please run this installation under windows 3.1 or higher.
I am trying to install an old DOS software called Run Master in Windows Vista. Any suggestions???
Then you need an older windows but NOT DOSBox.
You could install Windows 3.1 in DOSBox, then install your software. A thread about installing Windows 3.1 with SVGA resolutions is somewhere in the site.
I think you have to install window 3.1 but problem may be for old DOS software.
Trying to install new software. If you have more problem then tell me i will try me best.
Thank you.
wrote:You could install Windows 3.1 in DOSBox, then install your software. A thread about installing Windows 3.1 with SVGA resolutions is somewhere in the site.
right here
Patched SVGA driver for ANY new graphics card for use in Win3.1x.
