First post, by Great Hierophant
While many BX boards have a connector on the motherboard, many do not. For those that do not, yet you still want to run a PCI card using these signals (for maximum compatibility), this information should prove useful.
In Intel i440BX motherboards without this connector, you need to solder some wires to the PIIX4E 82371EB southbridge chipset to get this working. There are two components in the 5-pin connector, Serial IRQ and PC/PCI for DMA.
The pinouts of the PC/PCI connector are as follows:
REQ# 1 2 GND
4 GNT#
GND 5 6 SERIRQ
On the PIIX4E 82371EB, the appropriate signals will be found as follows:
REQ#A - M01 GNT#A - N01
REQ#B - N02 GNT#B - P02
REQ#C - P03 GNT#C - P04
SERIRQ - J19
Please refer to the datasheet of the PIIX4E 82371EB for the locations of the pins on the underside of the motherboard.
It does not matter which pair of PC/PCI REQ and GNT signals you use, so long as both are As, Bs, or Cs.
See this post regarding these signals with the Yamaha YMF-7xx chips:
http://queststudios.com/smf/index.php/topic,3041.0.html
You should attach 8.2K resistors between the REQ and GNT lines and VCC3 and a 2.7K resistor between the SERIRQ and VCC3.
Reply 1 of 8, by ux-3
I have a question there. I have never used SB-link with a cable. Is there a page on it somewhere? I used the live 5.1 in SB compatibility mode without such a cable, iirc.
Retro PC warning: The things you own end up owning you.
Reply 2 of 8, by swaaye
Rank Moderator
Moderator
The only Creative card that used it AFAIK was the Dell-only AWE64D (a PCI version of AWE64). That was a mysterious card that lived a very short life. See pic http://www.yjfy.com/Museum/sound/Creative_AWE64.htm
Once they bought Ensoniq, they started using Ensoniq's DOS driver for DOS support with all of their cards.
Reply 3 of 8, by Great Hierophant
SB-Link is Creative's name for PC/PCI connector. If you had an AWE64D card and a PC/PCI connector & cable, you should conceivably be able to install the card in a non-Dell system.
Reply 5 of 8, by PowerPie5000
My Yamaha PCI card uses the PC/PCI (SB-Link) cable for full DOS compatibility... it's great as my Yamaha card has "real" OPL3 hardware 😀
I use this card in my PIII system which is using an Intel SE440BX-2 motherboard (with PC/PCI connector).
Reply 7 of 8, by Great Hierophant
ux-3 wrote:
For those without the ability to see, could you name the card? Thanks 😉
See here:
Re: Yamaha WaveForce 192XG infos and drivers
