Reply 80 of 151, by EscapeVelocity
wrote:Escape, could you please try to edit your posts instead of posting lots of tiny ones? The edit button is the really small one on […]
wrote:What should I get, if the RAM doesnt pan out? […]
PC100
PC133128MB sticks
256MB sticks
512MB sticksEscape, could you please try to edit your posts instead of posting lots of tiny ones?
The edit button is the really small one on the top right of your postPC133 of course. And as I'm not sure what chip density will work on ss7 boards, your safest bet would be to get 256MB double sided ones.
Theres no compelling reason to go for PC100, it's just binned down PC133 anyway.
Get PC133 in case you ever want to overclock. Also you can set the cas latency to 2 instead of 3. Small bonus, but if it's the same efford, why not? Right?
Yes, is there a cost savings or something? Sorry.
Yeah, so get PC133 and I can downclock it, maximum flexibility.
256MB double sided SDRAM, got it.
Edit: Oops I did it again. Sorry.
