Reply 20 of 24, by Markk
- Oldbie
Here you are : http://www.uktsupport.co.uk/pb/mb/410.htm
Seems to me, it's worth replacing the cpu with a faster 486 and also adding some cache memory chips.
You don't need to close any jumpers in order for the external battery to work. You just connect it and that's it. Then it should maintain the settings. The battery in your link should be fine.
