First post, by superfury
Does the Compaq Deskpro 386 have a PS/2 mouse port? It probably has a PS/2 keyboard, but is a PS/2 mouse port installed as well? When I try to use UniPCemu, which uses a PS/2 mouse instead of a serial mouse on Compaq Deskpro 386 and PS/2 architectures, Cutemouse won't detect the PS/2 mouse(on the second PS/2 port)? The keyboard works without problems(also PS/2, on the first PS/2 port with scancode set translation optional in the PS/2 controller, which is still a bug in the current release of UniPCemu(it will also translate data of the PS/2 mouse the same way)).
UniPCemu Git repository
UniPCemu for Android, Windows and PSP on itch.io
