First post, by superfury
I notice that once the Compaq Deskpro 386 starts booting the OS, it calls the initialize function of interrupt 17h(the Printer BIOS interrupt vector) function 00h to initialize the parallel port. But when it's running, it sets the parallel port's SELECT and INIT line high by setting bits 2 and 3 permanently high? Thus peripherals like the Disney Sound Source(DSS) will turn on at boot, never to be turned off?
Anyone knows about this problem? Or is it an emulation problem and it doesn't happen on real HW?
UniPCemu Git repository
