Reply 1661 of 3552, by sharangad
robertmo3 wrote on 2024-05-27, 16:12:
sharangad wrote on 2024-05-27, 09:53:
Does anyone have vquake v1.06 and it's associated microcode? There's a report of a 486/Verité based system that has the same problems that I have with dosbox with vquake v1.08.
the reason was
Re: Rendition Verite Thread
Thanks for that! You saved me a lot of time.
https://patreon.com/Rready
Reply 1662 of 3552, by sharangad
Could someone with a Verité board run this and post the output (from Run.bat):
https://1drv.ms/u/c/5277ef8d4f2a9dcf/EUp6dvPN … 63WJww?e=pFfrHR
or
https://nirvtek.com/downloads/Fifo.20240528.001.zip
MD5: 1108f5f1b91b7e67a192e9a10082425d
What I'm actually after is the output of the INT10h 1580 call at the end and thanks!
Reply 1663 of 3552, by gplaps
Hi Sharangad
I was able to test the latest build with IndyCar II and most of the keyboard controls are functioning. 'W' still does not do anything, and 'F10' is also still not working, but otherwise the controls to adjust the car are working which is great!
The update to add 'threadsafe' to the conf file has improved performance a lot with the higher polygon mod carsets and they load correctly now. There are some small graphical glitches on the texturing for the higher polygon 3d wheels. Im not sure this is caused by the wrapper but I thought I would note it:
If you want to try this carset with higher polygon tires you can replace the default 'cars95' folder with this one:
The attachment cars95.zip is no longer available
I have recorded a video of how the game looks at one of the custom tracks which was able to load. There are some graphical glitches in the wall textures but I am not sure if this is an incompatible setting for the textures on the mod, or something to do with the wrapper.
https://www.youtube.com/watch?v=fWMsukX4WxA
Reply 1664 of 3552, by sharangad
gplaps wrote on 2024-05-28, 02:37:
Hi Sharangad
F10 should definitely work. Try this build:
https://nirvtek.com/downloads/Speedy3D.202405 … 7.Alpha.001.zip
MD5: 812bf0e104f75ead64898c6614eec13a
Going forward I'll add the latest build to the first post.
I think on faster systems it works ok. On slower ones it may kill the framerate, but DMA mode should be fully stable.
https://i.postimg.cc/D00zH39S/image.png […]
cars95.zip
Not sure. Will look into it.
The adverts on the barriers are corrupted. It could be that they're in an incompatible format or size OR the wrapper is messing the byte width up.
Which track is that?
Reply 1665 of 3552, by sharangad
@robertmo3, I retested my Haswell dual core/HD 4000 and it's actually faster with threadsafe=true (higher franerates, hits 30 fps after around 10s. Without this the framerate maxes out at 22 fps.
My ryzen/8 core with Gtx1060 has audio stutter at track load and then it's fine. No difference in frame rates.
Reply 1667 of 3552, by MSxyz
sharangad wrote on 2024-05-27, 23:36:
Could someone with a Verité board run this and post the output (from Run.bat): https://1drv.ms/u/c/5277ef8d4f2a9dcf/EUp6dvPN … 6 […]
or
Sure, I'll try it as soon as I'm back from work.
Reply 1668 of 3552, by gplaps
sharangad wrote on 2024-05-28, 02:52:
I have attached the track here. It is a total replacement for the "midohio" folder that comes with the game:
The attachment MIDOHIO.zip is no longer available
Reply 1669 of 3552, by sharangad
gplaps wrote on 2024-05-28, 10:38:
MIDOHIO.zip
Thanks! That's a job for tomorrow, unfortunately.
Reply 1670 of 3552, by MSxyz
or
Here's the output for my two V2x00 boards. One is the Diamond Stealth S220 4MB PCI, the other is the QDI Vision V2200 8MB AGP
Reply 1671 of 3552, by sharangad
MSxyz wrote on 2024-05-28, 14:15:
or
Both return the same thing, just like the other board. This app returned the right mem size but not the strings.
Thanks!
Reply 1673 of 3552, by sharangad
The update to add 'threadsafe' to the conf file has improved performance a lot with the higher polygon mod carsets and they load […]
cars95.zip
With the high res CARS95 models, edge antialiasing appears to cause the issue. Hitting [ALT+A] when on a track will disable edge AA.
https://youtu.be/Ah10I8Nd2EY
Reply 1674 of 3552, by sharangad
MIDOHIO.zip
This release should fix the issue with the high-detail MID-OHIO track.
https://nirvtek.com/downloads/Speedy3D.202405 … 9.Alpha.001.zip
MD5: d4e86db95698d0b73ea4b4053f77fc09
You can see it in action here:
https://youtu.be/GPsD3yzrKw8
Reply 1675 of 3552, by gplaps
sharangad wrote on 2024-05-29, 12:55:
This release should fix the issue with the high-detail MID-OHIO track. […]
MIDOHIO.zip
Thanks for the continued work on this! I was able to try this out and the issue appears fixed and the track looks great now.
I also discovered I wasn't properly replacing the RReady version of dosclient.exe and the dll files, so the "F10" issue was my fault and can confirm it now works as you describe.
Overall it appears like the game is working really well, the Anti-Aliasing toggle fixes the problems with the tire texture too.
I will continue testing, but for the default game it appears to run as expected!
One question I have is regarding the memory used by the wrapper. I have been using the following parameter when launching the game:
set SPEEDY3D_MEMSIZE=8
Does the card itself use 8mb or is it still using 4mb? It appears a lot of the modifications we have developed over the years use more than 4mb which is why we are unable to load a lot of the tracks with the 'Insufficient Memory' error. Is the 4mb a limitation of the card or is there an opportunity to include more memory? I do not know much about this topic so forgive me if it is a silly question!
Again, appreciate all the hard work on this!
Reply 1676 of 3552, by sharangad
gplaps wrote on 2024-05-29, 13:55:
Thanks for the continued work on this! I was able to try this out and the issue appears fixed and the track looks great now. […]
MIDOHIO.zip
The game appears to be rejecting the tracks based on the sizes of individual components.
Whep the game came out, Verité boards didn't have more than 4 MB of RAM and the Speedy3D API wasn't particularly forward looking to support more. Rredline has both a low level mode like speedy3d and a high level abstraction model.
The wrapper supports 128 MB of VRAM for RRedline apps when using the abstraction mode. For Speedy3D the structures used don't allow more than 16 MB of VRAM. In practice the api capped VRAM to 4 MB.
The environment variable is used by the speedy3d library static linked to the game, but it may be internally capping it to 4 MB, using the var only if it's below that.
The game binary (exe) is rejecting maps and tracks, long before anything is passed on to the wrapper.
The game would have to be hacked to increase the limit.
Also, if you could point me to some documentation on the .dat files maybe I can modify them to work.
You could try setting the environment variable to 16 MB, but I don't think it'll make a difference.
Reply 1677 of 3552, by gplaps
sharangad wrote on 2024-05-29, 15:05:
The game appears to be rejecting the tracks based on the sizes of individual components. […]
Hi Sharangad,
This program can be used to unpack dat files via dos command line:
The attachment dat.zip is no longer available
It would be placed in the same directory as the DAT file and can be used to unpack and pack dat files:
/unpack datfilename.dat
/pack datfilename.pck
The dat files contain all of the 3d (.3do) and texture (.mip, .mi4, .pmp, and some others) files for each track.
A lot of the addon tracks are much bigger than the base ones which came with the game, so it seems we are running out of memory because they contain many more textures. The tracks load correctly in the Dos version of the game, so the memory constraints written in the .exe file must be different dealing with rendition.
I will continue to explore
Reply 1678 of 3552, by checkpoint20
Hi sharangad, we were in touch on racesimcentral previously - posting over here to join the conversation. Really amazing progress lately and I've also been working to understand, using my Detroit Downtown mod, why the track doesn't load. Suspecting it is the memory limitation we have been talking about, so I hope there is a way to exceed the 4 MB.
You may have already noticed this but some of the modded tracks are not in .dat files due to a limitation in the number of files possible to pack into a dat file. But tracks that use more than approximately 300 files can have their folders unpacked and the game will load whatever is in the folder. However if a .dat file is present, I believe it will prioritize the file from within the .dat file first.
If you want more documentation on file formats, particular the 3DO and MIP file, those are here: https://www.simcyberworld.com/html/bbb/fileinfo.shtml
Some gaps in knowledge may also be discussed on the ICR2 forums: https://icr2.net/forum/
Reply 1679 of 3552, by sharangad
gplaps wrote on 2024-05-29, 15:37:
This program can be used to unpack dat files via dos command line: dat.zip […]
dat.zip
Thanks for that, but how do you edit a. Mip file? Do I have to use a special program for that?
[EDIT] This post is redundant. [/EDIT]
