DOSShark wrote on 54 minutes ago:Ok.
(1) Use ScummVM.
(2) Monkey Island 1 and 2.
(3) Set game specific settings in the way i mentioned in my last edited post abo […]
Ok.
(1) Use ScummVM.
(3) Set game specific settings in the way i mentioned in my last edited post above.
(4) In your player set midi through port as input
(5) Use your munt vsti Instrument with default settings.
(6) Play the game(s).
(7) On Monkey 1 the intro music is already broken for me.
Some things should be tried by you first:
1. Play the Monkey Ireland MT-32 Midi file with FSMP first and Munt VSTi loaded. Listen if you can experience the same problem.
2. Eliminate ScummVM from the equation. That is play the Monkey Ireland MT-32 Midi file with another Linux Midi Player through the same port you use with ScummVM so that FSMP + Munt VSTi loaded produce the sound.
Here are the MT-32 versions:
The attachment The Secret of Monkey Island - MT32.zip is no longer available
The attachment Monkey Island 2.zip is no longer available
