Reply 59320 of 60161, by BitWrangler
I don't know how the hell they got a patent on that when PCjr had external plug in expansions, the Amiga 1000 had "sidecars" and I think Sirius or someone did it in the CP/M and S100 space by having stackable modules.
Reply 59321 of 60161, by myne
H3nrik V! wrote on 2026-06-24, 15:36:
H3nrik V! wrote on 2026-06-24, 12:57:
myne wrote on 2026-06-23, 06:06:
I highly doubt it. Qpi is only to the southbridge. Sli is likely marginal thanks to the Sli bridge, but crossfire might get a ti […]
I highly doubt it.
Sli is likely marginal thanks to the Sli bridge, but crossfire might get a tiny boost.
Raid... Maybe but it seems unlikely that you would notice.
Haha,I was under the impression that the QPI link went to the chipset, who then "unfolded" to the PCI-express channels, as in I really thought that the CPU didn't have its own PCIe lanes onboard 🤣 I see I learn something new every day.
Did the Xeons then use QPI to inter-socket communication or is it really only to the south bridge? It seems like a horrible waste to have the increased speed on the 965 vs the 960 then?
Did a bit of reading. Looks like the i7-9xx (Nehalem based) doesn't have PCIe on board, but that it is on the chipset via QPI
Right you are.
My bad.
I guess they did the whole "move the northbridge on-die" in steps.
https://www.intel.com/content/dam/www/public/ … sheet-vol-1.pdf
I built:
Reply 59322 of 60161, by H3nrik V!
myne wrote on 2026-06-26, 07:31:
Right you are. My bad. I guess they did the whole "move the northbridge on-die" in steps. […]
Right you are.
My bad.
Interesting document. Thanks!
Reply 59323 of 60161, by cansting
Got working gen 2 XPS dimension for $35 today, good deal as 9800pro they shipped those with is worth more. What was my surprise when I got back home and discovered that there was no 9800 pro, just this bad boy...
Win98:
InWin A500 with Asus P2B, Pentium II 450, 512MB PC100, Creative 3D Blaster Annihilator Pro +Diamond Monster 3D II, YMF719E-S+ Diamond Monster Sound MX300
Win XP
Deepcool Tesseract with D875PBZ, P4 3.0 prescott, 3GB DDR400, HIS HD4670 iceq
Reply 59324 of 60161, by Ozzuneoj
cansting wrote on 2026-06-27, 02:07:
Holy smokes... an HD 4670 AGP is an insane find inside an old XPS. Congrats!
Reply 59325 of 60161, by cansting
Right? After finding this out had a small hope the CPU will be P4EE, but was a regular Northwood 🤣
Win98:
Win XP
Reply 59326 of 60161, by BitWrangler
Ozzuneoj wrote on 2026-06-27, 02:39:
IDK, I'd be more amazed to find one in a cheap case socket A, K7S5A board or something.
Reply 59327 of 60161, by Shader_BiH
Decided to move my attention to nVIDIA side for a while... Having only experienced FX5200 of the infamous FX line I decided to look for their higher tier cousins.
IMG-20260627-232900.jpg IMG-20260627-232915.jpg IMG-20260627-232933.jpg IMG-20260627-232949.jpg
At first I was aiming for an AOpen 5900XT with Hercules fan, it was very good condition but someone got to it before me... and than I found this baby, Leadtek Winfast A350XT. Visually look quite good and it was advertised as working. Can't wait to see what these "higher-end" FX cards can do. 🙃
Reply 59328 of 60161, by Ozzuneoj
BitWrangler wrote on 2026-06-27, 12:30:
Absolutely, that'd be even more crazy!
Still... opening up a Dell that was sold with a pretty well balanced high end video card + CPU combo from ~2003 and finding the last AGP card ever produced (from 2009) is pretty unexpected. Especially given the finicky nature of that card with regard to drivers (so I have heard). Someone apparently loved their XPS and wanted to keep using it as long as that old Northwood could hold out. Can't imagine running one of those for games in 2009 or later!
Reply 59329 of 60161, by cansting
Ozzuneoj wrote on 2026-06-27, 23:40:
Exactly my thought, enjoyable moment tho - looking for 9800pro and getting one ot the top3 agp cards ever existed (if not the best one)
Win98:
Win XP
Reply 59330 of 60161, by Xicor
hi everyone,
I have been busy whit work issues but in my spare time I still search far and wide for odd vintage computer stuff.
From friends I had some donations , 2 systems, 5 motherboards a couple of cards, also in the lot came a bunch of miscellaneous flat cables, floppy an optical drives drives of little interest.
First a Compaq persario 5166. It has a odd motherboard with a K6-II @333mhz, and a ESS Solo1 onboard. Luckily the onboard vram for the 530 SIS is present. The interesting thing about this machine is that Compaq went overboard with the marketing stuff, because the front label mentions some technology that is a bit of a stretch, like Aureal A3D, XG Wavetable and the cherry on top, the AGP logo (no agp was found in this machine).
The attachment Compaq_5166_01.jpg is no longer available
The attachment Compaq_5166_02.jpg is no longer available
The attachment Compaq_5166_03.jpg is no longer available
The attachment Compaq_5166_04.jpg is no longer available
The second system is a locally assembled machine by a store that has long been out of business, HB Informática. Midtower case, Pentium II motherboard and SB 16 vibra.
The attachment HB_tower_01.jpg is no longer available
...to be continued ..
Reply 59331 of 60161, by Xicor
3 Motherboard working, 2 of them slot 1, the other an LGA 775.
The attachment DFI_PA61.png is no longer available
The attachment Shuttle_HOT-661V_V3.1.png is no longer available
This Shuttle had a corrupted bios, and for some reason the retroweb had the info as if it was a VIA chipset, only that mine has an Intel Bx.... All the bios form retroweb failed. Managed to find a 128GB patched bios that did work from another source.
The attachment MSI_661FM3-V.png is no longer available
The other 2 had issues with shorts on power rails and failure to address the flashrom. Those are in the pipeline to be repaired.
The attachment MSI_845Pro_Ver1.png is no longer available
The attachment Matsonic_MS7117C_Rev2.2.png is no longer available
Reply 59332 of 60161, by Xicor
Also 2 cards that may be useful, a nic from digital, and a SounBlaster Live!.
The attachment DIGITAL_Nic.png is no longer available
The attachment Sound_Blaster_CT4830_Live.png is no longer available
In the acquisition front, I managed to find 2 motherboards fro MSI, and they stand decades apart.
The attachment MSI_MS5146.png is no longer available
The attachment MSI_X299_Raider.png is no longer available
For some, not vintage, but in the days of disposable everything, I feel that it qualifies.
Next a raiser for a somewhat obscure ACER motherboard...
The attachment Acer_1172_ISA.png is no longer available
Reply 59333 of 60161, by BitWrangler
Xicor wrote on 2026-06-28, 11:36:
hi everyone, […]
hi everyone,
I think the Compaq probably touted AGP because of internal AGP bus to SiS 3xx onboard graphics. I believe that line of machines is the sole reason that odd speed K6-2s like the 380 exist.
Reply 59334 of 60161, by BitWrangler
Xicor wrote on 2026-06-28, 12:14:
I always liked DEC NICs, and found them nice to run back in the day. Digital Equipment Corp were "in at the birth" of Ethernet and had a decade in the game before these Johnny come latelys like 3Com and Intel got into it.
Reply 59335 of 60161, by Ydee
hi everyone,
The integrated graphics chip in the SiS 530 is connected internally via the AGP bus, which is why the statement on the sticker is somewhat misleading—there is no external AGP slot, but technically, the PC does contain an AGP graphics.
The same may be true for audio—if a chip supports these standards even through software emulation alone, the marketing department is more than happy to highlight them in brochures and such. I have no idea if that’s the case with the ESS Solo mentioned here.
Edit: BitWrangler was faster 😀
Reply 59336 of 60161, by Xicor
Now the proper vintage and obscure hardware. One Acer 486 motherboard with a lot of integration an a eurocard interface for VGA. Cant find a single reference to the PC that this MB was part of.
The attachment Acer_1172_MB.png is no longer available
It has 2 sockets for 486, maybe for DX or SX, and a co-processor for Weitek 4167.
Also an ECS FX-3000, a 386/486 motherboard with a nice cpu and co-processor combo:
The attachment ECS_FX3000.png is no longer available
Next a Late 486 motherboard from Mitac, the PH4500A, Isa+PCI+VLB:
The attachment PH4500A.png is no longer available
Last but not the least, a beast of a motherboard from Fortron, the NetSet 486 EISA:
The attachment Fortron_NetSet_486_EISA_01.png is no longer available
It is obscure as it gets. The only info to track the brand was the uncommon bios post, that refers the model as being "NetSet Computer". It was made by Fortron, and the company is still around, now making the good quality PSU, but from 1991, I can only find a few ads from magazines. It does boot, but I have noticed some instability that I have tracked to IC U91, it needs re-flow on a couple of pins.
Reply 59337 of 60161, by Xicor
Ydee wrote on 2026-06-28, 12:32:
The integrated graphics chip in the SiS 530 is connected internally via the AGP bus, which is why the statement on the sticker i […]
hi everyone,
I do realize that the SIS 530 probably has a AGP capable core, but its implemented in silicon, there is no AGP bus outside the silicon. At least in Portugal it was common to see one of those machines running as a "demo" on stores, and obviously the sticker would induce the buyer to assume that an AGP slot would be available. Also the claim of XG wavetable, cant be from the ess Solo1, as I know it is only ESFM capable, and as far as I can understand it doesnt support A3D. So a sleazy deceptive tactic at best.
Reply 59338 of 60161, by Ozzuneoj
Xicor wrote on 2026-06-28, 16:38:
hi everyone,
Yeah, it seems like an outright lie for them to mention Aureal A3D 360° Sound (whatever that is) and Yamaha Wavetable. Unless the thing also had Aureal Vortex and Yamaha XG sound cards (or at least an XG soft synth), I can't see how it could possibly have all of those features in the same machine.
The AGP bus does exist in the system though. It is just occupied by the onboard graphics, so there is no AGP slot available. This one isn't an outright lie like the audio related stuff at least. I'm sure some at the time assumed that the AGP logo indicated that it had a free slot, but a system can make use of AGP features using an integrated AGP graphics solution connected via an internal AGP bus without actually having a physical AGP slot on the board. AGP was a big marking thing at that time (not sure if consumers actually cared or not), so I'm sure that any company that utilized AGP tech on some level made sure to show off the logo.
The mind boggles as to how they had the rights to use the A3D and XG logos on that system though. If I had to guess, they used those types of cards in other Compaq models and whatever terms they agreed to with Aureal and Yamaha to use their logos failed (possibly intentionally) to specify that the actual computer being sold had to have their product installed for the logo to be printed on the machine. Convenient for Compaq, not so nice for consumers or Aureal\Yamaha.
Hard to imagine that happening now, but companies played pretty loose back in those days. Now they just say things like "RTX 5070 = 4090 performance! ... For $549." Wait, that's pretty loose too. Glad to see some things never change. 😀
Reply 59339 of 60161, by rasz_pl
hi everyone
That is one impressive hardware dump! 😮
First a Compaq persario 5166. It has a odd motherboard with a K6-II @333mhz, and a ESS Solo1 onboard... The interesting thing about this machine is that Compaq went overboard with the marketing stuff, because the front label mentions some technology that is a bit of a stretch, like Aureal A3D, XG Wavetable and the cherry on top, the AGP logo (no agp was found in this machine).
Supermarket queen during $500 PC craze of dot com boom. Can only find mentions of 5166 in Portugal and South Africa 😮 all linked with some telecom promotions. https://www.vodafone.pt/en/press-releases/199 … ese-portal.html ~$250 up front + a very low low price of $25/month for 36 months 😁 bringing it all down to $1000 for $500 crappy PC in 1999.
Those super cheap K6-2 PCs from Compaq, Packard Bell, eMachines, Gateway were pure trap for anyone trying to do more than office stuff on a computer. Only the worst chipsets cpus and audio chips, sometimes no L2 cache at all.
Ozzuneoj wrote on 2026-06-28, 20:47:
Yamaha XG compatibility is just software Synth. They also shipped software library for some level of A3D compatibility.
Xicor wrote on 2026-06-28, 11:59:
Another Scam 😀
VIA chipset pin compatible with Intel, like here https://theretroweb.com/motherboards/s/shuttl … t-661v-v1.x-2.x
Shuttle probably made Intel versions first for good reviews just to later silently switch to cheaper VIA without changing name.
