Reply 60080 of 60159, by RetroAddict
oldGPU wrote on 2026-11-11, 16:53:
RetroAddict wrote on 2026-11-05, 23:19:
Another arrival today, I wasn't even aware these existed when they were current but it's a sweet little box that should make a good dos gamer!
Oh I love these.
If you have any idea where the hard drive is meant to sit I'm all ears! I can find nowhere, so my best guess is that it sits in an expansion slot mounted bracket!
I had another machine arrive today, If anyone is UK based and has a Tiny Computers Millennium recovery disc, I'd really appreciate it if you could upload it to the IA! I have two 98 restore discs but one of the latest machines shipped with ME, so I'd like to put it back to that!
Reply 60081 of 60159, by Shader_BiH
MattRocks wrote on 2026-11-11, 21:28:
You're my hero! Congrats on saving the card 😀
Do you have a photo of a muddy card so we can see the before and after? It could help me estimate odds when discovering dirty cards in the wild. I have a dirty motherboard/cpu/ram that I've not yet dared to clean/power..
Thanks 😁 I didn't take a picture before cleaning unfortunately, because I didn't have any hope it would work and that I would write about it 🤣. I guess it's a lesson for further cases 😀
But I can tell you what I think increases the odds. This card was heavily "armored" just as 9800 GX2, there is little to no PCB exposed to possible mechanical damage. Any sludge and dirt that found it's way in there must have got there while it was powered off, so theoretically there couldn't be any damage, and now when I think about it, washing it was probably the best possible course of action, because dirt can cause short circuit if it has any conductive particles, or if it draws dampness from anywhere. If you decide to do this with your hardware, just make sure it dries very well. Water can find it's way under chips, memory, etc. and it's difficult to get it out. Patience is the key. 😀
Reply 60082 of 60159, by myne
Shader_BiH wrote on 2026-11-11, 17:20:
Today I had a seriously lucky day... I went to the flea market and found a very dirty XFX 5870 Radeon... When I looked at it, my […]
Today I had a seriously lucky day... I went to the flea market and found a very dirty XFX 5870 Radeon... When I looked at it, my immediate thought was, there is no chance this works. There was sand... and mud in it... on the PCB and outside... So I gave 3 USD for it, and I planed to remove the heatsink and present a nice big PCB with Cypress XT core as display. When I got home I disassembled it and started cleaning it with isopropyl pads and spray cans, but it was so bad... that those didn't help. So in the end I decided, for the first time in my life, to wash a PCB, with water and soap... in the sink... and I did 🤣
After that I dried it for about 4 hours in front of fan, with mild temperature, and then I decided to take a risk and try it in my PC. I plugged everything in and kept my hand on the switch to turn everything off if things start burning or exploding. And then, it just booted... it just booted, went into Windows 10, took the drivers, and ran 3D mark, Tomb Raider Underworld, Blades of time, like a champ.... with perfect voltages, temps and stability... No hitches, no stutters, no graphical corruptions, absolutely 0 issues....
To be honest I am still shocked by this result. I never got to wash a graphics card... or any PCB for that matter, I just couldn't get over that somehow. As Jensen says, "It just works".
I also grabed a 9800 GX2 EVGA for same money, didn't wash it yet though... it's in the same mud and sand condition. Both cards actually look like they were in a flood or something...
People think electronics are magical.
They're mostly just metal, rock and plastic.
Without a current running through them they're practically as inert as anything else in the kitchen.
Obviously they corrode, but corrosion is something that happens in hours minimum.
Even the trace amounts of crap in normal water isn't much.
They use PURE water in fabs/mfg.
Dryness certainly matters after the wash.
Glad it worked for you!
I built:
Reply 60083 of 60159, by Nunoalex
CharlieFoxtrot wrote on 2026-11-11, 10:44:
Finally got this to my collection. Not that I had been super actively searching, but occasionally checking if somewhat reasonabl […]
Finally got this to my collection. Not that I had been super actively searching, but occasionally checking if somewhat reasonably priced units would pop up:
The attachment BatmanRevenge.jpg is no longer available
This is of course the Intel Premiere PCI/ED aka "Batman's Revenge" and with the just "Batman" among the first Socket 4 Pentium motherboards from 1993. It came with 32MB RAM, IO cables/brackets and above all with Pentium 60 SX835 CPU which still carries the infamous FDIV bug. Both the nature and where this motherboard stood on the marketplace and the CPU with a bug makes this combo IMO historically interesting.
It should be in fully working condition sans the empty Dallas. I might swap this combo with my Zida 4DPS mobo and AMD 486DX4-120 CPU in one of my builds at somepoint, but I more or less bought this because of what it is and as of now I have no serious plans what I'm going to do with it.
What an amazing find !
I still lack a socket 4 mobo in my collection, though I already have a Pentium 60
Reply 60084 of 60159, by TheAbandonwareGuy
myne wrote on 2026-11-12, 10:06:
People think electronics are magical. They're mostly just metal, rock and plastic. Without a current running through them they […]
Ah this is a great segway to my post.
I picked up a $10 barn find PC that was listed as a "Packard Bell 486". Was literally sitting out in a barn only marginally protected from the elements for 2 years.
What crack pipe this guy hit before posting it on Facebook I have no idea, because its clearly not a Packard Bell.
and based on the on-board USB I kind of guessed it wasn't a 486 either.
Turned out to be an Micronics C200 Super Socket 7 board with a 450MHZ K6-II, 192MB of RAM in an invalid configuration that detected as 64MB, an 8MB Riva 128ZX AGP, an Avance Logic LS-007 ISA sound card (which uses one of those OPL3 clones made from stolen chip masks), and a 10GB HDD.
To my amazement, everything worked once I reseated all the cards and removed all but one RAM stick. Even the floppy drive and the CD-ROM. Everything cleaned up OK but I ended up moving the board into another case. But this really shows how abused electronics can be and still function.
Cyb3rst0rm.com: Here There Be Screeds https://www.cyb3rst0rm.com
Reply 60085 of 60159, by BitWrangler
One of the boards in a case that my old shed leaked on then fell down on top of looks in better shape than some I have had stored wrapped up in antistatic bags in climate controlled house. But yeah, as long as they are powered off when all the nasty wet gunk happens to them and dried thoroughly before power applied again, they survive a lot.
Reply 60086 of 60159, by CharlieFoxtrot
I miss the days of copyright-infringing codenames. Nice pickup!
Indeed. Dead rock stars wasn’t a bad series of code names either. ”Joplin”, ”Morrison” and ”Zappa” followed the caped crusaders. I had Pentium 90 on Advanced ZP (Zappa) mobo back in the day. That got recycled probably over 2 decades ago, but I naturally have one such board humming in one of my boxes. I still have the CPU, CT2290, Diamond S3868 and broken HDD from that orginal system left, SB16 is even in regular use.
Anyways, the story goes that when at least Zappa code name was leaked outside the company (and that did happen, because the mobo was known as Zappa already in mid 90s) and Frank Zappa’s estate wasn’t happy about and complained or sent a C&D to Intel. That was the end of dead rock stars 🤣
Reply 60087 of 60159, by CharlieFoxtrot
Nunoalex wrote on 2026-11-12, 12:01:
Thanks, I like it too! I don’t think that these are actually super rare, these pop out for sale quite often and I think one can go to ebay almost at any point in Europe or US and get one if you really fancy it. To me the issue is that often the prices are just too steep for my tastes nowadays, even in local sales channels, until this popped up.
Reply 60088 of 60159, by H3nrik V!
LIF socket CPU removal tool. Will come in handy when I'm going to extract the dx4 overdrive from my PS/2 system.
Reply 60089 of 60159, by PD2JK
BitWrangler wrote on 2026-11-08, 17:41:
Seemed TNT2 cards went so long that the supply of original spec memory dried up. I have one from 2001 with ridiculously overspec memory on it. Maybe they were trying to use up a bunch that 3DFX had or had non-cancellable order for. 🤣
(Quote from the other thread) Looks like I got an Ultra. Now it only need some proper cooling. I'm thinking of a larger heatsink and just some airflow. These aren't getting hot.
The attachment 20261113_094543822.JPG is no longer available
has all kinds of stuff
Reply 60090 of 60159, by BitWrangler
Used to be 486 sinks you repurposed back in the day, but probably the cheapy etailers have a Raspberry Pi cooler that would be good for $5
Reply 60091 of 60159, by BitWrangler
H3nrik V! wrote on 2026-11-12, 19:31:
Secondary use, feng shui, zen garden rake for thermal paste on large GPU etc. 🤣
Reply 60092 of 60159, by amadeus777999
Very nice!
Reply 60093 of 60159, by Shader_BiH
Another catch at the flea market. Two sticks of Corsair XMS2 CL4 DDR2 800MHz - 2GB each. Gave 8USD for both. They are protected by the heatsinks so I though they should be fine. Tested today, both work. Didn't really have any "fancy" DDR2 in my collection, only generic Kingston sticks. This will add a nice touch to some Core2Duo build 😀
Reply 60094 of 60159, by RetroGamer4Ever
I took my Mom to get a rug and made a stop at a thrift store nearby the pickup and much to my surprise, I was able to get a pile of various DP cables - including DP-miniDP - and much to my absolute surprise, 32GB of XMS-capable DDR3 gaming RAM, in the form of two 16GB Dual-channel matched kits. I don't know if any of the old PC boxes I have around are DDR3, but I'll give it a look later and see if a retro-revamp is in my future.
Reply 60095 of 60159, by BitWrangler
RetroGamer4Ever wrote on 2026-11-13, 21:43:
You might get surprised by DDR3 in late socket 775 and also 1st gen Core takes it, BUT, they usually want 2GB modules. However, sandybridge, ivybridge, AM3 etc should suck them up.
Reply 60096 of 60159, by PcBytes
A bit of Satellite fun:
- Toshiba Satellite 300CDS - MMX 166, 16MB EDO RAM, C&T 65555 2MB, Yamaha OPL3-SAx
- Toshiba Satellite Pro SP4270 - Celeron 500, 320MB SDRAM, S3 Savage IX, Yamaha YMF744
- Toshiba Satellite 4070CDT - Celeron 366 MMC1, 64MB SDR, Trident Cyber 9525DVD 2.5MB, ESS Maestro-2
Reply 60097 of 60159, by fosterwj03
I ordered a Sound Blaster Vibra 16 from eBay late last night for $41 US shipped. This particular one, a CT2810, is so non-PnP that it has jumpers for sound IRQ, DMAs, and port addresses (important to me for Windows NT 3.1 and OS/2 2.x support). It also has a real OPL3 which doesn't matter that much to me, but it is nice to have. I got this card to replace the merely adequate OPTi 82C930 in my low-profile 486 machine with a POD83.
I had a Vibra 16 back in the mid-90's, so this card will bring back a little nostalgia. I think it's a better fit for my 486 as a result. I hope that the IDE connector on this SB16 doesn't need any initialization software like my 82C930 so it'll function without work-arounds on NT 3.1 and other operating systems which Creative didn't broadly support. I've got a contingency plan, though, if this SB16 IDE port needs to be initialized.
Reply 60098 of 60159, by Nexxen
PCIe riser cable, PCIe 3.0 from cooler master.
It'll make repairs easier allowing measurements laying flat.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 60099 of 60159, by PcBytes
This sunday was fairly nice:
- PS3 CECHC04 - backwards compatible unit (hybrid, but still), 60GB. No YLOD on top of that which is even more nice.
- Apple PowerMac G5, 1.8GHz DP model, 1GB DDR400, FX5200 and a PCI 1394 card. Had no harddrive so I prepped up a 160GB WD I had around.
- Enermax EG495AX-VE - nice PSU from the Prescott era. Only had to oil both fans.
