Reply 59360 of 59866, by dionb
H3nrik V! wrote on 2026-07-01, 05:39:
Yes, that's a funny note - but you wrote it yourself: "I guess they did the whole "move the northbridge on-die" in steps."
If I look at it, it seems like the 1156 launched close to a year later than 1366 did. I guess the 1366 was the first "flagship" on-die memory controller chip, where they only put the memory controller on-board, rather than everything all at once. The thing is that the on-board PCIe on 1156 was on the expense of "only" dual channel memory. (not that it really made any practical difference - but data sheets are data sheets 🤣 )
I guess the fact that the QPI link was scalable (4.8GT/s to 6.4 GT/s) made it possible to also scale the number of PCIe channels from the northbridge side, whereas the 1156 had one x16 interface. That was probably not enough for the HEDT platform in Intel's mind back then. Also, if I understand correctly, the QPI is also used on Xeons for inter-socket communications?
Not so strange at all if you look at the context.
LGA1366 was originally designed for the Xeon server platform, but - as several times before and since - Intel decided to introduce it in November 2008 as a high-end desktop platform as well. As with other platforms primarily intended for the server market, features were more geared towards bandwidth than latency. So big wide QPI path to an extermal chipset, where you could basically deploy as many PCIe lanes as you want. Sure, latency would be higher than if using a dedicated PCIe controller in the CPU, but for the workloads it was designed for, that was hardly an issue.
LGA1156 was a dedicated desktop platform with some nods and winks to laptop development. It not only moved the memory controller to the CPU like in LGA1366, but also included the northbridge and so the PCIe controller. The remaining chipset component - the PCH - was essentially a southbridge in all but name, and the DMI link between CPU and PCH was basically just PCIe as well.
The end result of the LGA1156 and later integration was a more modest bandwidth than LGA1366 offered and no sensible way to implement SMP, but with significantly reduced latency, so ideal for desktop use. These very different characteristics led to a divergence in benchmarks: things that thrived on raw CPU power and memory and PCIe bandwidth did a lot better on LGA1366 platforms, but things more sensitive to latency performed better on LGA1156. That meant that when it came to gaming, with a single GPU the LGA1156 scored better, but add a second GPU and LGA1366 came on top.
You saw similar things with later server->desktop platforms like the LGA2011.
Reply 59361 of 59866, by H3nrik V!
dionb wrote on 2026-07-01, 18:33:
Not so strange at all if you look at the context. […]
I can't really disagree with your analysis here, it's 2 totally different platforms. However, the i7 for 1366 released something like close to a year before 1156, so for early adopters, that was the way - using the HEDT platform.
Reply 59362 of 59866, by myne
Yes, that's a funny note - but you wrote it yourself: "I guess they did the whole "move the northbridge on-die" in steps." […]
myne wrote on 2026-07-01, 03:19:
You know what's confusing? 1156 has PCIE on-chip. 1366 doesn't. […]
H3nrik V! wrote on 2026-06-26, 12:17:
Interesting document. Thanks!
I do know that QPI is basically a variant of PCIE, so perhaps they figured a MUX on the chipset would be 'better'
If you do the math, pcie2 has 16x5gbit so it's faster than qpi. You might be on to something with the memory controller. Intel like to double up pin functions so maybe that explains it. -32 pcie pins +32 memory pins.
I built:
Reply 59363 of 59866, by Shader_BiH
PcBytes wrote on 2026-07-01, 16:00:
X1950 Pro 256MB came in yesterday. Managed to undo its unnecessary overkill Rialto cooling. […]
We went from this absolute UNIT of a ghetto Rialto cooling (which would be enough for a Pentium MMX!!!!!!)
The attachment rialto_ovrkill_cool.png is no longer available
To something more within normal ranges, recycled from a broken RS481 motherboard's southbridge, although I had to clip off the old pushpin holes (they wouldn't reach the screw next to the Rialto anyways) before pasting it on.
The attachment after_rialto.jpg is no longer available
For the concerned, the heatsink is NOT touching anything with its corners, and I've filed the corners to the fullest extent possible.
Great card! It just might be the best AGP solution for non top-tier CPU combinations. Something like Pentium 4 3.4 or Athlon 3200+ would work great with it I think.
Today one of my GPU hunts finally gave results. As I'm heavily into ATI red PCB hardware I was trying to find the Sapphire 3850 red card with that cool sticker on it. At first, it was mission impossible, as it appears there were a lot of different models of this card in different specs and PCB and cooler solutions. After quite a while I managed to identify it as early version of Sapphire 3850 256 MB PCIEx. That one went to reviewers back in the day. The second challenge was finding that card with sticker on it. I was searching for months.... There were some card available on e-bay, but apparently, due to high temperatures, those stickers came off, and there is not a single one left with sticker intact.... By some luck I managed to track down a card on Croatian "Njuškalo" market site, and managed to obtain the card from my contact in Croatia for just 25 euros....
It's just a beautiful card... Great condition, and it even came with original CD and cables... Very happy ^^
Reply 59364 of 59866, by nuno14272
The gravis is a clone one ! form Primax.. (yes the manufacrer of mouses).
Primax SoundStorm Wave Review
https://www.karlsitretro.com/primax-soundstorm-wave-review/
-but the gavis only emulates, and badly, the sound blaster.. so no option for mainstream.
The board is a QDI p4u880a/io. with a DX4-120.
https://theretroweb.com/motherboards/s/qdi-p4u880a-io
1| 386DX40
2| P200mmx, Voodoo 1
3| PIII-450, Voodoo 3 3000
Reply 59365 of 59866, by Nunoalex
Hi all
This just arrived today the Chips&Technologies F64300 VLB Card AKA Wingine GDX AKA expertcolor dsp64300
It is supposed to be on the high side of the VLB cards performance
It even has some slots for some suposed "cache" in windows accelelretion I would imagine
I already have a few Cirrus Logic, Trident and S3 805 VLB cards so I wanted to add this one to the collection
I payed 42 euros for it
What you guys think ?
Reply 59366 of 59866, by BitWrangler
Cool, be interesting to see if utilities for scaling etc for Chips laptop parts do anything on it.
Reply 59367 of 59866, by Shader_BiH
Nunoalex wrote on 2026-07-02, 21:03:
Hi all […]
Hi all
It's in lovely condition... By the state of slot contacts it doesn't appear to be used much. It would be interesting to see performance scaling with different cache configs.
Reply 59368 of 59866, by Nunoalex
Shader_BiH wrote on 2026-07-04, 08:35:
Hi all […]
Hi all
As soon as I track down some compatible chips (the board has marking MT4c4256 ) I will post some results
But I think I read here on the forum that this is only affecting windows performance and has no effect in DOS
Reply 59369 of 59866, by SlowA
Shader_BiH wrote on 2026-07-02, 12:29:
Great card! It just might be the best AGP solution for non top-tier CPU combinations. Something like Pentium 4 3.4 or Athlon 320 […]
Good find.
If you need anything from Njuškalo, feel free to be in touch.
Reply 59370 of 59866, by Ozzuneoj
I had pretty much accepted the fact that I was unlikely to ever find an original Aureal retail box, and then stumbled upon this and had to grab it!
The attachment 20260704_144025.jpg is no longer available
The attachment 20260704_144048.jpg is no longer available
The attachment 20260704_144105.jpg is no longer available
The attachment 20260704_144142.jpg is no longer available
The attachment 20260704_144254.jpg is no longer available
As far as I can tell, Aureal only ever had two retail boxed products with their own branding that actually made it to market. The SQ2500 in 1998, and the SQ1500 in 1999. I see some mention of the SQ2200 (Aureal branded Diamond MX300) and Vortex Advantage (the little L-shaped AU8810) being sold by Aureal, but I can only find evidence of them being used in OEM systems or sold by third parties in non-Aureal packaging. If anyone has pictures of Aureal packaging of either of those though, please let me know! (There is also, of course, the unreleased SQ3500, which someone has recreated the box for in recent years.)
The first sound card I ever bought (and my first ebay purchase, since they were already off the market) was an SQ2500, so they have always occupied a special place for me. This box has definitely been crushed a few times, but it is overall not in terrible condition and I don't see any hint of UV bleaching (sun or fluorescent lighting), which is kind of amazing after 27 years.
AU8810 based cards aren't real rare, but the actual SQ1500 models like this with a coax digital output seem to be pretty uncommon.
Reply 59371 of 59866, by pan069
nuno14272 wrote on 2026-07-02, 13:21:
I have come to believe that this was a conscious business decision by Gravis. Pretty much anyone back then who was "interested" in having an UltraSound (including myself) already had a Sound Blaster (or compatible clone). Would Gravis produce the UltraSound with Sound Blaster compatible hardware, which meant a higher retail price for the UltraSound, or would they exclude the Sound Blaster hardware compatibility for a lower retail price with the assumption that the majority of their customers would already have a Sound Blaster compatible audio device?
Reply 59372 of 59866, by SlowA
Bought Asus Striker II Extreme & Zalman WB5 in mint condition:
After Socket A & Socket 939 & ATi, I plan to assemble THE configuration with Intel&nVidia(s)
Reply 59373 of 59866, by Shader_BiH
SlowA wrote on 2026-07-05, 18:17:
Bought Asus Striker II Extreme & Zalman WB5 in mint condition: https://i.postimg.cc/44S8jQWP/Screenshot-2026-07-05-201042.png h […]
Really cool piece of hardware. Great condition and it's quite a catch that it comes with that sound card... I was looking one as well on BiH OLX market, but no luck finding such boundle. And thanks for the offer 😁 I will definitely contact you, Njuškalo seems to have better retro offers than OLX at the moment.
Reply 59374 of 59866, by supercordo
Thats Sexy!!!
Reply 59375 of 59866, by SlowA
Keep them coming...
CCBBE Opteron 185, hardly can do better than this on S939
X1950 XTX - the first GDDR4 memory ever - LOOKING FOR CROSSFIRE DONGLE/ADAPTER if someone knows someone. 😀
Another gold, the last ATi chipset before AMD bought them - RD580
There is definitely something when you can afford to achieve a dream build, even if it's a 20-year-old dream. 😀
Reply 59376 of 59866, by Shader_BiH
SlowA wrote on 2026-07-07, 10:21:
Keep them coming... […]
Keep them coming...
Great XTX there... I think I've seen that one on e-bay :3 I grabbed one few months ago as well 😁 Are you planning any specific build with it?
Reply 59377 of 59866, by SlowA
I am a sucker for period-correct builds, so this one will be a final season of S939 (2005/2006):
Opteron 185 (FX-60, but server-grade silicon), ATI RD580 chipset ASUS A8R (up to 3.2V VDIMM), Winbond BH-5 UTT 4x512MB, ATi X1950XTX Crossfire (if I ever find a Crossfire cable) WD Raptors in RAID 0, X-Fi Sound Blaster... assembled in Coolermaster Stacker 830.
Reply 59378 of 59866, by Shader_BiH
SlowA wrote on 2026-07-07, 16:00:
Sounds like a real muscle build 😁 I'm also planning a socket 939 build, but a bit more modest one, since I am limited by motherboard (Medion 7075). I will make mine around Athlon64 4000+ (It's not an FX but it's very close at high resolutions and details)
Meanwhile... another card came around.
For a while I was trying to catch a 128-Bit model of MX 4000, and then this card appeared out of nowhere. It wasn't even expensive... about 20 dollars. It's an Sparkle MX4000 (SP7310 A5 128MB DDR AGP). Performance wise, it should be a bit below 128-Bit MX440.
Reply 59379 of 59866, by Living
well, after 27 years i can finally cross this one from the bucket list. A client was upgrading the computer and he wanted to downsize in terms of cables and mess, plus the Live ct4760 (wich has a date code 9851, one of the earliest productions) doesnt have a place in new motherboards and windows 11.
this was a wet dream for my teenage ass back in the day and i believe the FPS1000 is one of the first 4.1 available on the desktop market. They sound really nice, i only had to swap the AC Adapter for a newer one and adapt the power connector, clean the potenciometer and all the speakers in general, came out really good.
