First post, by DaveJustDave
i've had a lot of luck with the 3C509, but can't seem to find anything at all for the 3C515... does anyone have a workaround to get this working in DOS?
The attachment IMG_20180509_081502.jpg is no longer available
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 3 of 14, by Grzyb
jfabienke wrote on 2025-10-01, 17:32:
Perhaps you would like to be the first to test my unified 3Com DOS Packet driver?
I would like to try it.
But... where's the EXE ?
Do I need to compile it myself?
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 4 of 14, by BloodyCactus
https://github.com/jfabienke/3com-packet-driver
how much of this was made by ai and have you tested any of it on real hardware? Makefile doesnt work for me, and includes config files that dont exist (build/build_config.mk etc)
I find it interesting that its meant for dos but not buildable on dos (all those long filenames).
 wmake info
Open Watcom Make Version 2.0 beta Aug 22 2025 11:49:07 (64-bit)
Copyright (c) 2002-2025 The Open Watcom Contributors. All Rights Reserved.
Portions Copyright (c) 1988-2002 Sybase, Inc. All Rights Reserved.
Source code is available under the Sybase Open Watcom Public License.
See https://github.com/open-watcom/open-watcom-v2#readme for details.
Makefile(203): Error(E24): More than one command list found for (PRODUCTION)
Makefile(210): Error(E21): Extension(s) (.PHONY) not defined
Makefile(210): Error(E09): Ignoring out of place Path Specifier
Makefile(210): Warning(W79): Makefile may be Microsoft; try /ms switch
Makefile(270): Warning(W18): Unrecognized or out of place character '='
Makefile(271): Warning(W18): Unrecognized or out of place character '='
Makefile(272): Warning(W18): Unrecognized or out of place character '='
Makefile(272): Warning(W18): Unrecognized or out of place character ','
Makefile(273): Warning(W18): Unrecognized or out of place character '='
Makefile(291): Warning(W18): Unrecognized or out of place character '='
Makefile(292): Warning(W18): Unrecognized or out of place character '='
Makefile(293): Warning(W18): Unrecognized or out of place character '='
Makefile(293): Warning(W18): Unrecognized or out of place character ','
Makefile(298): Warning(W18): Unrecognized or out of place character '='
Show last 23 lines
Makefile(299): Warning(W18): Unrecognized or out of place character '='
Makefile(300): Warning(W18): Unrecognized or out of place character '='
Makefile(300): Warning(W18): Unrecognized or out of place character ','
Makefile(309): Warning(W18): Unrecognized or out of place character '|'
Makefile(316): Warning(W18): Unrecognized or out of place character '|'
Makefile(322): Warning(W18): Unrecognized or out of place character '|'
Makefile(328): Warning(W18): Unrecognized or out of place character '|'
Makefile(339): Warning(W18): Unrecognized or out of place character '|'
Makefile(345): Warning(W18): Unrecognized or out of place character '|'
Makefile(372): Warning(W18): Unrecognized or out of place character '|'
Makefile(376): Warning(W18): Unrecognized or out of place character '|'
Makefile(380): Warning(W18): Unrecognized or out of place character '|'
Makefile(399): Error(E24): More than one command list found for (build/%.obj)
Makefile(399): Warning(W18): Unrecognized or out of place character '|'
Makefile(424): Warning(W18): Unrecognized or out of place character '|'
Makefile(526): Warning(W18): Unrecognized or out of place character '|'
Makefile(590): Error(E24): More than one command list found for (verify-patches)
Error(E02): Make execution terminated
Reply 5 of 14, by Grzyb
The only devtool shipped with DOS is a Basic interpreter - and some versions lack even this.
When releasing a piece of software written in any other language, executable is a must!
Reply 6 of 14, by ntalaec
I have recently found this web that compiles all know packet driver for DOS:
http://packetdriversdos.net/
Reply 7 of 14, by Grzyb
ntalaec wrote on 2025-10-02, 08:34:
Nice, but there are three important problems:
1. there's no packet driver for 3C515
2. existing packet drivers for 3Com PCI cards are known to be buggy
3. there's no DOS drivers of any kind for 3CSOHO100B
So, the project to make a completely new PD for various 3Coms is potentially precious - I really hope it succeeds!
Even though the 3CSOHO100B seems to be beyond the scope of that project.
Reply 8 of 14, by dinornis
I have a device running DOS 6.22 with a 3C515 network card. The official network card drivers provided by the manufacturer are as follows (located in two folders in the root of the C: drive). I hope this information is helpful.
Grzyb wrote on 2025-10-02, 13:09:
Nice, but there are three important problems: 1. there's no packet driver for 3C515 2. existing packet drivers for 3Com PCI card […]
Reply 9 of 14, by jfabienke
BloodyCactus wrote on 2025-10-01, 23:35:
how much of this was made by ai and have you tested any of it on real hardware? Makefile doesnt work for me, and includes config […]
 wmake info
Show last 23 lines
Just added the Open Watcom wmake file for DOS-native builds.
Reply 10 of 14, by rjbrown99
@jfabienke any thoughts of creating a release on Github with a downloadable .exe? I'd be happy to test but I'd like to avoid the hassle of trying to figure out how to compile this in DOS. Thanks!
Reply 11 of 14, by megatron-uk
I'm not convinced this has ever been fully compiled or tested. I've tried building it (Open Watcom + NASM on Linux) using the 'build_macos.sh' script and while it *does* generate some object files, there's a lot of errors, and some of the assembly code that NASM chokes on looks "off" to me (though I will admit that I do not know x86 assembly).
Open Watcom "wmake" doesn't like it at all. So I didn't bother investigating that route any further.
It's also huge. I've never seen a Dos packet driver with over 1MB of compiled code before - even if some of it is "loadable overlays".
https://www.target-earth.net
Reply 13 of 14, by aVd
Tried to build with Open Watcom 2.0 - got errors like these. Just another a."i." bullsh33t.
what comes around goes around
Reply 14 of 14, by Grzyb
More often than for "Artificial Intelligence", the "AI" stands for "Artificial Idiocy"...
