Reply 220 of 609, by FreddyV
GloriousCow wrote on 2024-08-28, 19:39:FreddyV wrote on 2024-08-28, 19:28:I mean is there enaugh disk image available in all the format so that it is worth adding support ?
There is a significant body of images from both historical archival efforts as well as modern ones. It might be enough to support just the modern formats, but supporting the older ones may be helpful in the case where such images may be the only existing images of that particular software. It's true you can always convert some format to another, but such efforts can be tricky. I've seen posts on VOGONS with someone explaining a dozen different steps using the PSI tool, that even I barely understand. It would be nice to just be able to throw any format you might encounter at MartyPC and have it work without needing a doctorate in floppy engineering.
Hi,
The PicoMEM is acting at BIOS interrupt level, it means that not all the fonctionality of these images will be possible.
This limlit the compatibility, but can surely be better then nothing, not all the disk has copy protection.
