Reply 30380 of 31724, by Locutus
yourepicfailure wrote on 2025-10-29, 04:59:
Well, just when I found time to open up and start fixing the 1740A: Someone hands me a 1725A... […]
The attachment 1725-scope.jpg is no longer available
Sadly don't have the space for both so the 1725A will be the keeper. Will need some fixes, but this will probably be an even better scope for me when I get it going.
1725A has quite good bandwidth - it will be a useful tool.
I love the glow of analog oscilloscopes CRT (I have a few Tektronix scopes), but for a long time now, I've only used the digital Rigol...
Reply 30381 of 31724, by Delerious
Ozzuneoj wrote on 2025-10-29, 07:08:
Delerious wrote on 2025-10-29, 05:49:
Got the right(-ish) drivers to install for my ATI FireGL T2-S64 card. Thank Phil for an old video he happened to have on that particular card.
Now I'm trying to figure out why my mouse stutters when extracting files in Windows 98. That said, if anyone knows why this is, please let me know.
Is it a USB or a PS/2 mouse? And what are the specs of the system?
USB. Running on an AMD Thunderbird 1.0 GHz with 512 MB RAM, using and nForce chipset with the latest drivers for said chipset. OS is Win98. I'd read that USB can cause issues with some older systems, but haven't looked into details on what kind of behaviors to expect in those scenarios.
Current builds:
Asus A7N266-VM | AMD Athlon @ 1.0 GHz | 512 MB DDR RAM | ATI FireGL T2-S64 | Windows 98 SE/Windows 2000 Professional
Asus H61M-Plus | Intel Core i5-3570S | 8 GB DDR3 RAM | AMD FirePro W4300 | WinXP Pro x86/Win7 Pro x64
Reply 30382 of 31724, by bjwil1991
Did a bit more work on the 5155 - potentiometers and installing expansion cards.
The system is easier to work on than the 5150 that always gives me problems. Once I get the software for my NX Pro, I'll change the volume output and go from there. I just can't believe the untested 5155 works without issues.
Reply 30383 of 31724, by Dan386DX
6x86L PR166 arrived. Gave it some sea trials.
Will overclock to a stable 188 MHz (3*66) - scores 29FPS in Quake time demo (320x200), similar to a Pentium 100. Just Cyrix FPU things 😁
It will actualy POST at 210 MHz, but stability falls apart quickly.
90s PC: IBM 6x86 120Mhz. 128MB/6GB. ATI Rage Pro 3D.
Boring modern PC: R9 3900X, RX 7800XT. 32GB/1TB.
Fixer upper project: NEC Powermate 486SX/25. 16MB/400MB.
Reply 30384 of 31724, by PcBytes
Restored a SR440BX to its former glory.
I also apologize for underestimating the power of it. Apparently this thing has 3.1 support.
Reply 30385 of 31724, by sunkindly
Starting to get frustrated with a Socket 7 M-Tech Rise R529 motherboard...everything online says it supports a 3x multiplier / 200MHz but a Pentium MMX 200 is still only at 2.5x multiplier / 166MHz. I've triple checked the jumpers, set 1.5x (still stayed at 2.5x), not sure what to do. BIOS also updated to the latest available (1997).
Reply 30386 of 31724, by PcBytes
Tried everything on a MSI BX Master... only to find out that I likely have a likely bad (as in erased) PAL chip.
That's gonna be fun to fix.
Reply 30387 of 31724, by Ozzuneoj
PcBytes wrote on 2025-10-31, 01:55:
Doh, that sounds bad.
If you don't mind explaining, how did you narrow the problem down to that? I'm always looking for tips to diagnose weird problems.
EDIT: Is it the GAL mentioned on this page? https://theretroweb.com/motherboards/s/msi-ms-6163-v3.0-bx13
Reply 30388 of 31724, by PcBytes
Yup, that's the chip, although peeling the label mine seems to be marked as PAL. Whichever it is, seems it's blanked out and I need to get my hands on a TL866 to get it alive. I was almost INCHES close to swapping the SC1153 chip blindly, until I remembered this board uses a GAL chip. Already replaced ALL caps as well as reflashed main BIOS to latest.
Will genuinely have to get a TL866 ASAP as one of the boards in the recycler lot I have to go thru is a K7 Pro... which uses that same godforsaken GAL.
Reply 30389 of 31724, by Ozzuneoj
PcBytes wrote on 2025-10-31, 03:08:
I love my TL866A, I highly recommend them! It has saved several projects of mine. I recently used it to test a big lot of cache chips I purchased too, which I didn't even know it could do when I bought it.
Anyway, it's awesome that the community has supplied the file necessary to re-flash the GAL on that board. Such an obscure thing, and yet it can be done with the right programmer and chip. Hope it goes smoothly for you. 😀
Reply 30390 of 31724, by Ozzuneoj
This is kind of a weird activity, but... well, this is the kind of stuff I find myself doing.
I picked up a scrap lot a few months ago and I discovered after receiving it that it had all or most of the PCBs from a Roland XP-10 GM\GS keyboard, including the little screen. I have not heard one of these, but I think it probably sounds different from a Sound Canvas. I guess these were made from 1994 to 2002, and looking at the little chart on the main PCB it looks like this may have been built in November of 1997... though I can't say with certainty.
Anyway, what I'd like to try to do (before I resort to just selling the boards for parts to repair a more complete XP-10) is see if there's enough here to get the thing taking in a MIDI signal and outputting sound. I think there is enough here to do that, though all of the wires connecting the boards together are missing, so that alone could stop the project dead in its tracks. I am mostly concerned about whether the volume control will be "all the way up" or just "broken" without the volume slider connected. Also, if any buttons need pressed to get it to accept input, that will be an issue. I have all the buttons, but they are no longer connected to anything.
It's also very likely this thing was toast already and that's why it was dismantled and scrapped. I guess we'll see. 🤷
EDIT: Well, I've got it hooked up and it should be receiving a MIDI signal but I'm getting no sound. I think I need the volume control at the very least, but it's possible I need to enable the playback of midi input as well. It is warming up though, so I don't think it's 100% dead.
It's too bad. If the cables\wires had all still been connected I might already have it making sound.
Reply 30391 of 31724, by RetroBus
Cleaned and resurrected an Athlon 64 System I got on Facebook Marketplace, Looks like its been through a bit and seen some things in its time, upgrades and hackjob repairs the Northbridge Cooler was really a nightmare
Video Below:
https://www.youtube.com/watch?v=mHSGr_t3H_I
https://www.youtube.com/@ComputerRetroBus Computer Retro Bus - My Youtube Chanel
Reply 30392 of 31724, by GigAHerZ
Printed some RAM holders for my SDR/DDRx and So-DIMM memories.
Used this one:
https://www.thingiverse.com/thing:4847265/files
For top piece, i just used slicer to set an area that has no walls and no infill. Result is cut off poles for the top piece.
Now i need to desing similar thing on my own for 72pin and 30pin ram sticks...
A little about software engineering: https://byteaether.github.io/
Reply 30393 of 31724, by zuldan
RetroBus wrote on 2025-10-31, 09:22:
Video Below:
https://studio.youtube.com/video/mHSGr_t3H_I/edit
Need a proper link 😝
Reply 30394 of 31724, by PC@LIVE
sunkindly wrote on 2025-10-31, 01:43:
Hello, if I understand correctly you have an S.7, but the CPU goes to a maximum of 166 MHz, so first of all 😨 I would check what is written on the CPU, for example Pentium XXX MMX SXXXX (the X's indicate what you will find written, they are important), already from there it would be possible to better understand the problem.
Then if maybe 🤔 you can take some photos, and attach them here, possibly motherboard and CPU, or if you can jumper zone (multiX), it would be possible to compare your settings with those of the manual (if you have one), but in any case even in the absence of the manual, it is possible to do some tests, to see to set the jumpers on 3X, currently it should be on 2.5X, if instead it is on 3X and does not go to 200, speaking of Intel CPU, you could have a 166 MHz CPU with multiplier blocked to go up.
If so, the only way to increase the frequency is to raise the FSB, if that board allows it, you can switch to 75 MHz, you get 188 MHz that the BIOS could interpret as 180 or 200 MHz, maybe that's how they showed you the 200 MHz.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
Reply 30395 of 31724, by RetroBus
zuldan wrote on 2025-10-31, 09:46:
Video Below:
Ah yes, thanks for bringing that to my attention 😀, updated the link, but here it is again
Reply 30396 of 31724, by zuldan
RetroBus wrote on 2025-10-31, 11:52:
Video Below:
Another great video by the way. Appreciate you making this content.
Reply 30397 of 31724, by PcBytes
Ozzuneoj wrote on 2025-10-31, 03:35:
Yeah, I think there's also the file for K7Pro - which I'll probably need as well.
Reply 30398 of 31724, by sunkindly
PC@LIVE wrote on 2025-10-31, 09:51:
Hello, if I understand correctly you have an S.7, but the CPU goes to a maximum of 166 MHz, so first of all 😨 I would check what […]
Photos below, but in doing some more testing...it seems like the jumpers don't do anything at all to change it from 2.5x.
The attachment r529multjp.png is no longer available
So JP16 and JP17 seem to set the fsb, but for JP19, JP20, and JP22 no matter what I set them to...it didn't change from 2.5x at 166MHz. Even setting it to something "normal" like 133MHz at 2x, nothing changed. The only thing that seemed to affect change was changing the FSB through JP16-17. But unfortunately, it doesn't support more than 66MHz.
The attachment IMG_7685.jpg is no longer available
The attachment IMG_7682.jpg is no longer available
The attachment IMG_7683.jpg is no longer available
The attachment IMG_7684.JPG is no longer available
The silkscreen doesn't mention anything about P55C or a 3x multiplier, but it has the jumpers to set dual voltage (which I did) and since it's POSTing I'm assuming that's actually working. So I'm not sure...
Reply 30399 of 31724, by sunkindly
It's probably fate though cause I really don't like the design of this board anyways (who thought it was a good idea to put ports between the PCI and ISA slots...)
