Tillamook 266MHz and working L2 cache?
Reply 520 of 567, by Artex
That did cross my mind as well. I do have at least 6 or 7 SS7 boards to try and will certainly do so. Just curious as this was my first tested board and feel like it’s optimized as best as can be.
Don’t get me wrong, it’s still pretty awesome getting this performance out of this chip, but something under the surface is apparently gimping the SpeedSys score and was interested to see if anyone else has tried this combination of hardware.
More to come!
Reply 521 of 567, by Nemo1985
Artex wrote on 2024-11-21, 23:39:
More to come!
If you have it I'd use a GA-5AX rev. 5.2. Same chipset just a earlier revision. You are right, maybe we expect too much from the pentium mmx cpu despite the impressive frequency. I'd suggest to do a quake benchmark on this configuration and then on the other one, it's notorious that is optimized pretty well for intel's fpu and you will be able to see if the problem is the cpu or the asus motherboard according to the result.
Reply 522 of 567, by Artex
I do have 2 of those boards, both Rev 5.2, so I’ll try that next. The fact that we can even run these chips on these boards is amazing in itself. Getting over 60 fps in software mode Quake is sweet stuff.
Reply 523 of 567, by RayeR
I recently tested some MBs with Tillamook and found there are significant performace differences between various chipset, here's my table:
http://rayer.g6.cz/hardware/tillamok.htm#CPU_TEST_TABLE
E.g. some MBs with SDRAM performed worse than with FPM DIMM, some run slower at non-standard FSB over 75MHz and more compared to basic 66MHz and such quirks. Finding a good MB that supports Tilly and have good performance is not easy...
Reply 524 of 567, by Nemo1985
That's interesting.
I remember I did a round up of cpus at 200mhz some time ago (I also did a 250 but I didn't test the tillamook because I still didn't have it), with a Aopen AX59 PRO the performance were the same between a standard pmmx and a tillamook.
Reply 525 of 567, by Artex
RayeR wrote on 2024-11-22, 01:20:
This looks like an amazing deep dive. Thanks for referencing this and putting in all the work. I’ll check this out when I’m fresh tomorrow.
Reply 526 of 567, by Nemo1985
Artex wrote on 2024-11-22, 02:49:
Weird results indeed, I'm going to try to compare with the same frequency since it seems they are not so consistent:
MB 	CPU 	fCPU 	fFSB 	fPCI 	Vcore 	Speedsys CPU/MemBW 	Memtest RAM/L1 	VESATEST 	Quake 320/640*
GA-5AA Tillamook 233 266 MHz 66 MHz 33,3 MHz 2,0 V CPU: 197,84 / 285,26 MB/s 145 / 174 MB/s 34 MB/s 57,8 / 16,0 FPS
M590A Tillamook 233 266 MHz 66 MHz 33,3 MHz 2,0 V CPU: 198,64 / 154,45 MB/s - 18 MB/s 51,1 / 11,2 FPS
M577 Tillamook 233 266 MHz 66 MHz 33,3 MHz 2,1 V CPU: 198,62 / 410,06 MB/s 102 / 102 MB/s 43 MB/s 51,4 / 18,2 FPS
PA-2005 Tillamook 233 266 MHz 66 MHz 33,3 MHz 2,5 V CPU: 197,84 / 222,52 MB/s 138 / 171 MB/s 55 MB/s 52,8 / 17,7 FPS
PA-2005 Tillamook 233# 266 MHz 66 MHz 33,3 MHz 2,5 V CPU: 197,84 / 222,52 MB/s 138 / 171 MB/s 55 MB/s 54,7 / 17,9 FPS
Apparently the best results are achieved with the GA-5AA, which is a at version of the GA-5AX, if i'm not mistaken?
I definitely need to do another roundup at 250mhz with all the cpus I have now, I will do it when I am in the right mood, that's the link to the very old one: Super socket seven round up at 250mhz
Reply 527 of 567, by Sphere478
Nemo1985 wrote on 2024-11-21, 23:33:
Weird but the p5a 1.05 and 1.06 are notorious for being bugged with k6-x+ cpus maybe something similar happens with this one?
Do you have any other ss7 motherboard to try with?
Yeah, trying the 1k wt/wb resistor mod would be interesting. Shouldn’t hurt anything on tillamook I wouldn’t think. It may be the issue.
Sphere's PCB projects.
Reply 528 of 567, by Nemo1985
Sphere478 wrote on 2024-11-22, 03:39:
I remember there was an interesting topic about it, but it was tricky I remember something stopped working with such mod, have those issues been troubleshoted and solved?
Reply 529 of 567, by RayeR
Nemo1985 wrote on 2024-11-22, 02:59:
GA-5AA has good clock steps settings but has poor memory/AGP/PCI bust throughput.
Look that FIC PA-2005 at 75MHz FSB beat GA-5AA at 83MHz. Crappy Ali chipset vs better VIA.
Reply 530 of 567, by Nemo1985
RayeR wrote on 2024-11-22, 06:07:
You should also consider the pci clock, in the ali chipset at 75mhz is underclocked, while on the via motherboard is overclocked.
It may be interesting to see what's the difference between the ali chipset and the via mvp3.
Reply 531 of 567, by H3nrik V!
Nemo1985 wrote on 2024-11-22, 06:11:
The ALi chipset has a /3 PCI divider?
Reply 532 of 567, by gonzo
Here is my Tillamook-project:
- 266-MHz-CPU stable overclocked to 440 MHz (FSB 110 MHz x 4 / 2,5 Volt Vcore) using soldered wires directly on the CPU as shown on the previous pages in this thread (no adapter)
- Gigabyte GA-5AA Rev. 3.2, L2-cache of 512 KB enabled/active
- Radeon 9000 (64 MB)
- 256 MB SD-RAM at 110 MHz, CL 2
Results in Windows ME:
- GLQuake: 48,7 FPS
- Quake II: 30,8 FPS
Results in DOS:
- Quake I: 91,7 FPS
- DOOM: 156,6 FPS (477 realtics)
- in System Speed Test 4.78, the performance is similar to a Pentium II 300 MHz (I would expect something slightly better)
I LOVE CPUs RUNNING IN [GonzoHz]
Reply 533 of 567, by gonzo
And here the rest of the pics.
BTW, the CPU-frequency shown as 450 MHz at POST is wrong - they are real 440 MHZ
Reply 534 of 567, by Sphere478
Very nice^
Nemo1985 wrote on 2024-11-22, 03:43:
The p5a 1.05 1.06 has a whole host of issues. Only one of them is solved by that mod.
Search asus p5a simple mod. The thread will pop up.
Reply 535 of 567, by Artex
I swapped to my AOpen AX59Pro and had some much better results, although for whatever reason I had to pump a lot more voltage into the chip to get it stable than when using the Asus P5A 1.06 board. I am not comfortable running it with this voltage for any length of time.
Processor: Intel Pentium 266 w/MMX "Tillamook"
Motherboard board: AOpen AX59Pro (1MB L2 Cache)
Memory: 1 x 256MB PC133 SDRAM
BIOS: R2.36
Chipset: VIA VT82C598MVP (Apollo MVP3)
Processor Mods:
  • Green (VCC2DET)
  • Yellow (L2 Cache)
  • Blue (BF2 4X Multi)
SpeedSys: 303.08
Quake: 74.6 fps
Jumper Config:
CPU BUS Frequency Multiple (4x) (but according to the manual this is a setting for 2X):
  • S1: on
  • S2: off
  • S3: off
FSB (100Mhz)
  • Jp4: 1-2 short
  • JP5: 1-2 short
  • JP6: 2-3 short
  • JP25: 2-3 short
Voltage (2.7V)
  • S4: on
  • S5: on
  • S6: on
  • S7: off
  • S8: off
Reply 536 of 567, by gonzo
Artex wrote on 2024-11-23, 17:50:
It would be not very correct what I mean, but, I think, if you stay at any voltage less than 2,8 V (= standard Vcore for the "standard" Pentium MMX P55C, before Tillamook), you will not damage this CPU (or the risk of damage is not too high).
I mean, a Tillamook-chip is not too different from the P55C (even they are differences of e.g. no support of dual-CPU-environment etc.) - the mean reason for using 1,8 to 2,0 Vcore is the laptop-ability for the Tillamook (longer battery operation), as well the 250 nm of Tillamook versus the 350 nm of P55C. Of course, the less the Vcore is, the better.
Reply 537 of 567, by Artex
Artex wrote on 2024-11-21, 23:48:
I cannot seem to find the right combination of jumpers + switches on this board. All the documented FSB and multipliers seem to not work correctly with this chip. Anyone have this board and know the correct combination to get to 100FSB with 4x multiplier or even 100FSB with 4.5x for 450mhz (or anywhere inbetween using FSB of greater than 100Mhz)?
Reply 538 of 567, by GeorgeMan
Hi, tried my Tillamook on a Shuttle HOT-579 which has jumper settings to set 2,1v lowest voltage. So I set it to 2.1v, measured the output of the power transistor just to make sure I won't fry it, installed and voila.
Bios said Tillamook-MMX and then froze.
So I did the yellow and blue mods (not the green for the forced voltage detection, not the red for the L2 and not the orange), installed it back and it just worked at 4x66=266 😁
Unfortunately, this motherboard is unstable at 83MHz FSB with any RAM and any CPU (tried PC133 SDRam at the slowest settings and a K6-2 500 which works on another board at 83x6), so I ended up at 75x4=300MHz. That way it completed all of the benchmarks just fine.
It a nice little boost, considering that I didn't expect miracles, just an uplifted P-MMX. It of course loses to K6-2 due to raw MHz power of the latter.
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 539 of 567, by Sphere478
GeorgeMan wrote on 2024-11-29, 07:56:
Hi, tried my Tillamook on a Shuttle HOT-579 which has jumper settings to set 2,1v lowest voltage. So I set it to 2.1v, measured […]
Nice!
Maybe disabling onboard hardware like IDE and using external card would help?
