Reply 200 of 860, by nd22
- l33t
AlexZ wrote on 2025-10-15, 07:28:nd22 wrote on 2025-10-06, 07:30:6. Storage devices: as much as I would liked to use SSD half of the boards refused outright to run with a SSD connected! In fact only 2 out of 4 accepted a SSD. On VIA K8T800 PRO with the VT8237 there is a known problem when only SATA 150 drives are accepted or SATA 300 that can be jumpered to SATA 1.5 speed. On nforce3 despite trying multiple brands no SSD worked. Unfortunately I do not have a Sand force based SSD so I could not trick the boards into accepting flash based storage!
I did some testing with s754 nForce3 250 that someone ended up purchasing. I found out that Intel SSD 480GB is detected by BIOS correctly and can "sometimes" boot into Windows XP. There seems to be a timing issue on boot - everything proceeds normally until the Windows XP progress screen is meant to appear. It freezes there on 1st attempt. After reboot, Windows detects a problem and offers safe mode. I select standard boot and it boots. Once it boots, everything works fine. But the first boot always freezes. Maybe newer NVidia SATA driver would help. I used one from manufacturer's website which is often not the latest. Magnetic SATA drive didn't exhibit this problem. Parallel ATA also works fine as expected. So on nForce3 250 and VIA, a fast magnetic drive is probably the best choice.
During my testing I also found out that 2 out of my 3 GeForce 7600 GT are unstable. They must have degraded over time. One was previously used in s754 AGP build and worked fine in January this year. Probably old ball grid array issue as I did cool them properly. It must manifested after a few years.
Unfortunately my problem is more serious: with a SSD the system freezes on startup without letting me into the BIOS. So I can't do anything, change any setting as long as the SSD is installed.
