First post, by superfury
I notice that running Windows 95 under many Dosbox versions has various problems with either booting a disk image or the serial port (if it actually manages to boot).
One problem that happens on most Dosbox distros (except Dosbox-X and SVN Daum(is Dosbox-X actually a continuation of SVN Daum? It seems to have the same icon?)) seems to be that it gives me a bootloader error (Operating System not found or comparable message).
Then, on the cases it does actually boot (Dosbox-X/SVN Daum), it doesn't seem to actually detect the serial modem, no matter what I put in the serial port settings. Tried "modem", "modem listenport:5000" and "modem listenport 5000" for both serial1 and serial2 (Windows is setup for COM2 for the serial port).
Or in the cases it does boot, I'm met with all kinds of weird crashes of Explorer.exe and other programs (even during the boot, after the GUI displays the desktop).
UniPCemu Git repository
