First post, by Robin4
Here is the manual.
How to use:
1. I have renamed atc6240.djvu to atc6240.zip (because djvu wont getting excepted here. And otherwise i have to handle a 7.2 Mb file.
2. Download it and rename the extension back to djvu.
3. There are convertors online which will convert djvu to PDF file and then its useable. Otherwise you need a djvu reader.
Reply 1 of 8, by Horun
Robin4 wrote on 2021-09-17, 23:11:
Here is the manual. […]
Here is the manual.
How to use:
Good find ! Last year found a bunch of Atrend and other manuals in WPC and other old formats. Some were even BitFax raw files 🤣
Reply 2 of 8, by Robin4
also got it now in 2 parts in a self extracting archive.
Reply 3 of 8, by BitWrangler
Horun wrote on 2021-09-17, 23:24:
Gah yeah, PC Chips is bad for that, find their old manuals and it's a .doc, but that could be a plain text file, a wordpad/rtf doc or a word for windows 5 or 6 document, and it's as bad as putting in a USB you have to try three times until you get the right one. Fax format, heh long time since I've seen that, used to be a mid 90s thing, how stuff got online when the manufacturer didn't have a website yet, TIFF files I remember, but there was a couple of others.
Reply 4 of 8, by Stiletto
Here is the manual.
How to use:
I think it's a good idea to just convert such old things to PDF when you can, and upload to archive.org or send to UH19 or something.
do the Fandango!" - Queen
Stiletto
Reply 5 of 8, by Horun
evasive and I tried to convert some old odd formatted Word+ early .ppt manuals for UH19 but never totally succeeded on a few of them. One was the ATC-1535 which seemed to be a Word doc but had odd wingdings that could not be replicated.... iirc
Reply 6 of 8, by Horun
Here is the manual.
How to use:
Ok after conversion and running through Acrobat 6 Pro was able to create a 1.3Mb PDF without loosing much detail, much smaller than the full 7Mb conversion.
There is a scan error on page 45 where you cannot read a full sentence of text. It exists in the .djvu file and cannot be corrected.
Good find ! The original plain ATC-6240M manual, not the V updated versions.
added to Vogons Library: http://www.vogonsdrivers.com/getfile.php?file … 1&menustate=0,0
Maybe evasive or deksor will add it to UH19 (I seem to have lost my login ugh!)
Reply 7 of 8, by AmiSapphire
Great find! I actually own that motherboard version, too! (Needs a bit of repair, though.)
Site update: cwcyrix.duckdns.org -> cwcyrix.nsupdate.info due to the former no longer working.
Reply 8 of 8, by Robin4
AmiSapphire wrote on 2021-09-18, 23:57:
Iam using that board in my new Pentium II build.. Iam busy on it. Things running, but need another scsi cable and find some solution to cool my Seagate Cheetah 36GB LVD Ultra 3 10.000RPM drive.
Which its running on a Adaptec AHA2940uw2 controller.
