First post, by deepthaw
I’m beating my head against the wall trying to get EMS with an AGP GeForce 4MX 420 installed in a 440BX system.
It’s definitely the GeForce, I swapped it in to replace a Radeon 7000. When Emm386 starts it says it’s unable to set page frame address. No matter how I play with different I M and FRAME settings I can’t seem to get it working. I tried QEMM and let it try to automatically configure itself it just ends up hanging repeatedly with similar messages.
I suspect the GeForce bios is just occupying too much memory - any tips on software to troubleshoot or otherwise figure it out?
Reply 1 of 11, by retardware
Why not use MSD and Manifest to look where the ROM area is, and start by experimenting with conservatively setting memory ranges, expanding them by trial and error?
Reply 2 of 11, by deepthaw
retardware wrote on 2021-09-25, 16:07:
Wasn’t aware of those. I’ll track them down and give them a shot.
Reply 3 of 11, by Gmlb256
deepthaw wrote on 2021-09-25, 16:03:
This is the problem, I have two AGP GeForce cards and their Video BIOS takes about 64KB of the upper memory segment. So you can't use C800-CFFF range for anything, you can only use the D000-EFFF range no matter which memory manager you use.
Reply 4 of 11, by deepthaw
Gmlb256 wrote on 2021-09-25, 16:37:
Do you have a config line that already works with one of those cards? It’ll be less of an issue once my isa sb16 comes in and I don’t need EMS to emulate sound in DOS.
Reply 5 of 11, by Gmlb256
deepthaw wrote on 2021-09-25, 17:57:
Yes, I have one on my Slot 1 computer with QEMM. For simplicity sake I will display the CONFIG.SYS line for EMM386 which can help with your situation.
DEVICE=C:\DOS\EMM386.EXE RAM FRAME=D000 I=E000-EFFF
This config line assumes that there are no other ROM devices located around D000-EFFF range.
I used the MS-DOS 6.22 directory since I don't know which version you are exactly using, you can also include I=B000-B7FF but will break compatibility with monochrome video modes. For QEMM I suggest adding X=F000-FFFF in addition to the other parameters because that's the ROM BIOS location and without this it causes stability issues.
Reply 6 of 11, by deepthaw
Gmlb256 wrote on 2021-09-25, 18:05:
Yes, I have one on my Slot 1 computer with QEMM. For simplicity sake I will display the CONFIG.SYS line for EMM386 which can hel […]
That caused a restart at boot. Reinstalled QEMM and ran MFT. Looks like my Ultra66 ide controller is sitting right in prime real estate.
nbnnQmv_d.webp?maxwidth=640&shape=thumb&fidelity=medium
So I’m guessing I either need to: use BW area, switch back to Radeon, or remove the Ultra66 controller.
Reply 7 of 11, by Gmlb256
deepthaw wrote on 2021-09-25, 18:29:
Removing the Ultra66 controller will fix it in this case without changing anything. If you want to use the B000-B7FF range as UMB without removing the HDD card then use the following parameters.
FRAME=D800 I=B000-B7FF I=E800-EFFF
You will get less UMB this way though.
Reply 8 of 11, by Gmlb256
One more thing, does your motherboard has ROM around the E000-EFFF range? I recall this with a Gateway motherboard and it didn't allow me to use most of that address range.
Reply 9 of 11, by Matth79
If the EMS requirement can be satisfied by 4.0 spec (not compliant with 3.2), then you could try
P0=B000 P1=B400 P2=D800 P3=DC00
Before that, try the HIGHSCAN parameter to see if it can allocate into the E000 block - it only needs to find one more page ... E000-E3FF and it could allocate a D400 page frame
Reply 10 of 11, by maxtherabbit
EMM386 can use E000-EFFF for the page frame. Add 'M9' to the command line
Reply 11 of 11, by deepthaw
Thanks all, I ended up just removing the Ultra66 card and now emm386 auto ram just works with no further tweaks. Qemm inevitably locks up the computer if I try running optimize but the other utilities look great so I’ll keep it on the hdd.
