First post, by Digidreamer
Hi just a quick question,
upgrading a EGPU Nvidia card, all the newer cards seem to use a 5v (Red) cable from Molex to Video card in stead of the usual 6 wire 12V Yellow / Black Combo
Checking first so a don't put 12v where 12v don't supposed to go or are they interchangeable??
    14.38 KiB
    898.95 KiB
I Like Charity Shops, they're like steam and GOG but cheaper.
Windows 7 - HP730 Air cooled, 8Gb, GT1030
Windows 98se - Wyse V10LE 1.2Ghz, 1 Gb, 16Gb SSD
Windows 98se - Compaq Evo 550d SSF, P4 2Ghz, 1Gb, 60Gb(Partitioned)
Dos 6.2 - HP7510 512Mb, 4Gb
Reply 1 of 2, by BitWrangler
The point of those types of molex connectors is that they can't be plugged into the wrong socket because the square and rounded pin shields won't match up... in theory.. so I would make the assumption that if it plugs into the connector, it should work... Really I'd just use it to confirm a no-go before doing more research. i.e. if it doesn't fit you definitely need the redwire version... if it does fit it looks promising but you're gonna have to pull tech docs to confirm, because sometimes Tech companies be like "Screw standards"
Reply 2 of 2, by Digidreamer
Thanks,
can't find a straight answer anywhere. red looks like it's on the Negative, Usual Molex is the 2 negatives are in the middle with 12 and 5 v each side.
if so, why use the red cable and throw the schematics out???
