First post, by AndalusianRG
Hello everyone!
I'm still suffering with an Amstrad PC3286 that I've recently bought😅😅
This model in particular has a 286 at 16MHz, but in the Setup the maximum speed I can choose is 12MHz😅
Any help would be appreciated!
Reply 1 of 18, by Doornkaat
The CPU does not have a multiplier. It runs at whatever frequency the board runs it at.
If you can not set a higher speed on the board your best bet is overclocking by changing out whatever generates the clock (most often an oscillator can).
Reply 2 of 18, by AndalusianRG
Doornkaat wrote on 2021-10-02, 20:12:
Two of the oscillators onboard are of 64 and 48 MHz 🤷🏼‍♂️🤷🏼‍♂️
The memory access speed is set at 100ns.
Thank you for your reply!
Reply 3 of 18, by Doornkaat
Often one of the oscillators is for deturbo mode, the other for regular mode.
Is it possible you're running the PC in deturbo mode?
As always good pictures help in figuring out what's going on.😉
Reply 4 of 18, by konc
This particular model was only sold as a 286/16, no other cpu options were available. So oscillators should be the right ones for 16MHz.
The strange thing is that OP cannot set the speed to 16MHz in BIOS, but I'm not familiar with its BIOS screens. Perhaps some photos could help.
Reply 5 of 18, by AndalusianRG
konc wrote on 2021-10-03, 07:35:
https://drive.google.com/file/d/1Mpoo-ALs6BP4 … ew?usp=drivesdk
Reply 6 of 18, by konc
AndalusianRG wrote on 2021-10-03, 07:54:
So it's not not a PC3286 as you wrote in your initial post which does have a 16MHz CPU, but a PC2286 as the BIOS says with a 12MHz CPU 😁
Reply 7 of 18, by AndalusianRG
konc wrote on 2021-10-03, 08:15:
It's a PC3286, but it seems I'm not using the proper SETUP 😅
https://drive.google.com/file/d/1MtwdO9q8av7b … ew?usp=drivesdk
Reply 8 of 18, by konc
AndalusianRG wrote on 2021-10-03, 08:23:
Come on help us a bit more here, we keep trying to guess! So you run the setup from a disk? If so then yes, you need the correct disk to show you the options for your model. You hadn't noticed until now or you thought it would work?
Reply 9 of 18, by AndalusianRG
konc wrote on 2021-10-03, 08:34:
I run it from the only SETUP I found on internet : http://www.freetimeweb.nl/home/computer/alt/l … awson/atpcs.htm
Unfortunately I don't own the original disk... :'(
Reply 12 of 18, by konc
AndalusianRG wrote on 2021-10-03, 08:56:
konc wrote on 2021-10-03, 08:44:
AndalusianRG wrote on 2021-10-03, 08:40:
CTRL+ALT+S doesn't work?
It doesn't, for no reason.
OK there's something weird going on here, the 3xxx series can access the BIOS even by pressing DEL at the startup, you don't need a setup disk for it and that's the reason you cannot find any mention of one anywhere. Have you checked the PC inside to make sure it looks like a 3286? I don't have any other ideas.
Reply 13 of 18, by AndalusianRG
konc wrote on 2021-10-03, 09:01:
It has a 286-16 processor...I don't know what else I can tell 🙁
Reply 14 of 18, by AndalusianRG
https://drive.google.com/file/d/1MtwdO9q8av7b … iew?usp=sharing
Here it says the computer is a 3286.
Reply 15 of 18, by weedeewee
What speed are utilities like checkit, norton sysinfo, landmark speed test, ... reporting the cpu to be running at at the moment?
Do not ask Why !
Reply 16 of 18, by AndalusianRG
weedeewee wrote on 2021-10-03, 10:00:
I definitely should try some of those utilities. Maybe it's running at 16MHz despite that the BIOS sets it at 12.
Reply 17 of 18, by weedeewee
AndalusianRG wrote on 2021-10-03, 10:18:
Considering the setup program you are using was for a different computer that only went to 12 MHz...
Do not ask Why !
Reply 18 of 18, by AndalusianRG
weedeewee wrote on 2021-10-03, 10:57:
With 3DBench it appears 9.7 FPS. That's a good sign! 😄
